Full Version: Font size
I just installed Kodi after being away for a couple of versions and then the Rapier skin. It is super awesome - thank you!
I was wondering what the correct method is for changing the font size to make it bigger? I couldn't find any UI for this, just this post. Is that the correct method?
Hi arangas.
Thanks a bunch for the kind words.
You actually only have two font options within Kodi when using Rapier - default and Arial.
If you want to increase the font size, you need to manually edit Font.xml inside the skin.rapier/720p folder.
Be aware that all edits are overwritten with each update of the skin, and I strongly encourage everyone to keep the skin updated Smile
there are a ton of font lines of code to change .
any easy way of sorting?
Which font set do you use?
You can change just the one font set you use.
