2015-06-18, 12:42
I have a problem adjusting the video size inside video/CDVDDecoder::OpenStream().
In Helix the hints.aspect was normally set to a value giving me the possibility stretching the video by setting iDisplayWidth / height to get it visibly correct.
In Kodi Isengard I normally get the aspect value 0 and have no possibility to adjust the settings.
Regarding CDVDCodecAmlogic.cpp it is line 191ff:
For reproduction:
- TVHeadEnd
- PVR Addon
- Choose a german SD Channel (WDR3 / SAT1 or similar)
- My screen resolution: 1080p
- Latest release from Master with Odroid XU3 specific MFC Decoder for Video
Has there be anything changed? I could try to figure the problem out but then it would be great if somebody can explain in some words the internal workflow (files / methods would be optimal).
Currently this happens:
- Video is opened
- DVDDecoder say that its not decodable because hints are invalid (first frames do not contain enough information)
- FFMPEG Decoding is activated until the necessary information are present (width / height / fps, (aspect ratio?))
- DVDDecoder is opend again with success (hint are valid, but unfortunately aspect is 0)
Thanks for your support and the great kodi application!
if (m_hints.aspect > 0.0 && !m_hints.forced_aspect)
m_videobuffer.iDisplayWidth = ((int)lrint(m_videobuffer.iHeight * m_hints.aspect)) & -3;
if (m_videobuffer.iDisplayWidth > m_videobuffer.iWidth)
m_videobuffer.iDisplayWidth = m_videobuffer.iWidth;
m_videobuffer.iDisplayHeight = ((int)lrint(m_videobuffer.iWidth / m_hints.aspect)) & -3;
For reproduction:
- TVHeadEnd
- PVR Addon
- Video is opened
