Full Version: VNSI: Since mid/end may channel scrabled/encrypted message
Hello,
i am using OE 6.0 Beta 2 right now and since the last update from vnsi i have massive problems with encrypted programms. After channel switch i have several error codes from vnsi 2,5 and 7.
vdr log says:
Jun 19 11:27:06 OpenELEC vdr[14422]: [15388] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1535
Jun 19 11:27:09 OpenELEC vdr[14422]: [15388] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1535
Jun 19 11:27:13 OpenELEC vdr[14422]: [15388] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1535
These problems are only on pay tv and therefore encrypted channels but the SmardCard is okay and activated and alive. Also SmartCard backend is configured and in a functional state... SmartCard Backend and vdr are not changed since march/april. The problems occured first since update of dvbapi/vnsi server mid/end may.
here some logs with enabled dvbapi log = 3
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: inserting new filter, demux=0, filter_num=1
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_SET_FILTER request, adapter_index=0, pid=1008, demux_idx=0, filter_num=2
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=0 set FILTER pid=1008 start=1, demux=0, filter=2
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI:    --> FILTER: 82 40 00 00 00 00 00 8C 4B AA 00 00 00 00 00 00
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI:    -->   MASK: FF C0 00 00 00 00 FF FF FF FF 00 00 00 00 00 00
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: inserting new filter, demux=0, filter_num=2
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_SET_FILTER request, adapter_index=0, pid=1008, demux_idx=0, filter_num=3
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=0 set FILTER pid=1008 start=1, demux=0, filter=3
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI:    --> FILTER: 82 40 00 00 00 00 00 00 00 00 00 8C 4B AA 00 00
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI:    -->   MASK: FF C0 00 00 00 00 00 00 00 00 FF FF FF FF 00 00
Jun 19 12:02:08 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: inserting new filter, demux=0, filter_num=3
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 CA_PMT decoding len=1f lm=5 prg=107 len=19
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: ci_cmd(G)=01
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 got CA pmt ciCmd=1 caLm=5
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 answer to query suppressed
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 set CAM decrypt (SID 107 (0x006B), caLm 5, HasCaDescriptors 1)
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: send: channelSid=0x6b (107)
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: Write, sock=13
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: socket_fd=13 len=51 wrote=51
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 CA_PMT decoding len=6 lm=3 prg=0 len=0
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 got CA pmt ciCmd=-1 caLm=3
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] DVBAPI: 1.0 stop decrypt
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_STOP request, adapter_index=1, pid=1A0B, demux_idx=1, filter_num=0
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=1 set FILTER pid=1A0B start=0, demux=1, filter=0
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleting filter, demux=1, filter_num=0
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleted the last filter for pid=1A0B, removing list
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got CA_SET_PID request, adapter_index=1
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: 0.-1: set pid 0x02ff
Jun 19 12:02:09 OpenELEC vdr[21050]: [21111] DVBAPI: 0.-1: set pid 0x0303
Jun 19 12:02:09 OpenELEC vdr[21050]: [21366] EEPG: setstatus 0
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: 1.0 CA_PMT decoding len=15 lm=4 prg=116 len=0
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: pid=2,03ff len=0 (0x0)
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: pid=6,0403 len=0 (0x0)
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: pid=6,0404 len=0 (0x0)
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: 1.0 got CA pmt ciCmd=-1 caLm=4
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: 1.0 answer to query suppressed
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: 1.0 set CAM decrypt (SID 116 (0x0074), caLm 4, HasCaDescriptors 0)
Jun 19 12:02:09 OpenELEC vdr[21050]: [21659] DVBAPI: CA_PMT doesn't contain CA descriptors
Jun 19 12:02:10 OpenELEC vdr[21050]: [21110] EEPG: setstatus 0
Jun 19 12:02:10 OpenELEC vdr[21050]: [21110] EEPG: setstatus 1
Jun 19 12:02:10 OpenELEC vdr[21050]: [21110] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 CA_PMT decoding len=1f lm=5 prg=107 len=19
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: ci_cmd(G)=01
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 got CA pmt ciCmd=1 caLm=5
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 answer to query suppressed
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 set CAM decrypt (SID 107 (0x006B), caLm 5, HasCaDescriptors 1)
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: SendStopDescrambling
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: Write, sock=13
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: socket_fd=13 len=8 wrote=8
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 CA_PMT decoding len=6 lm=3 prg=0 len=0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 got CA pmt ciCmd=-1 caLm=3
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] DVBAPI: 0.0 stop decrypt
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_STOP request, adapter_index=0, pid=1008, demux_idx=0, filter_num=1
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=0 set FILTER pid=1008 start=0, demux=0, filter=1
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleting filter, demux=0, filter_num=1
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_STOP request, adapter_index=0, pid=1008, demux_idx=0, filter_num=2
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=0 set FILTER pid=1008 start=0, demux=0, filter=2
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleting filter, demux=0, filter_num=2
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_STOP request, adapter_index=0, pid=1008, demux_idx=0, filter_num=3
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=0 set FILTER pid=1008 start=0, demux=0, filter=3
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleting filter, demux=0, filter_num=3
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleted the last filter for pid=1008, removing list
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got DMX_STOP request, adapter_index=0, pid=1A0B, demux_idx=0, filter_num=0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: adapter=0 set FILTER pid=1A0B start=0, demux=0, filter=0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleting filter, demux=0, filter_num=0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: SetFilter: deleted the last filter for pid=1A0B, removing list
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: Action: Got CA_SET_PID request, adapter_index=0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: 0.-1: set pid 0x02ff
Jun 19 12:02:11 OpenELEC vdr[21050]: [21111] DVBAPI: 0.-1: set pid 0x0303
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] EEPG: setstatus 0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] EEPG: setstatus 1
Jun 19 12:02:11 OpenELEC vdr[21050]: [21050] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 12:02:11 OpenELEC vdr[21050]: [21660] EEPG: setstatus 0
Jun 19 12:02:11 OpenELEC vdr[21050]: [21660] EEPG: setstatus 1
Jun 19 12:02:11 OpenELEC vdr[21050]: [21660] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 12:02:11 OpenELEC vdr[21050]: [21110] EEPG: PMT scan idle
Jun 19 12:02:12 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:13 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:14 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:15 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:16 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:17 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:18 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:19 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:21 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:22 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:23 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:24 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:25 OpenELEC vdr[21050]: [21050] EEPG: setstatus 0
Jun 19 12:02:25 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:26 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:27 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 1023
Jun 19 12:02:29 OpenELEC vdr[21050]: [21660] VNSI-Error: cParser::AddPESPacket - max buffer size rea
i had already problems with the last vnsi server version and picture artifacts every 20-30 seconds. This seems to be solved by setting priority once to -99 and back to -1.
when i switch to another channel and then back it is very likely the channel is decrypted.
any clues?
forum rules do not allow talking about softcams. please remove oscam related things.
try current master of vnsiserver and post syslog with vdr logging set to 3.
Sorry, it was not my intention to talk about softcams at all.
currently i am stick at git rev a7b0670 due OE which was latest master half an hour ago. i don't have any build environment installed.
But here the log:
Jun 19 16:05:26 OpenELEC vdr[3796]: [3796] EEPG: setstatus 0
Jun 19 16:05:26 OpenELEC vdr[3796]: [3857] EEPG: setstatus 0
Jun 19 16:05:26 OpenELEC vdr[3796]: [3857] EEPG: setstatus 1
Jun 19 16:05:26 OpenELEC vdr[3796]: [3857] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 16:05:27 OpenELEC vdr[3796]: [3857] creating new channel 'Comedy Central Poland HD,;Harmonic' on S13.0E transponder 110853 with id 318-11700-1201-0
Jun 19 16:05:27 OpenELEC vdr[3796]: [3857] creating new channel 'Fashiontv loriginal HD,;Satlink' on S13.0E transponder 110853 with id 318-11700-2001-0
Jun 19 16:05:27 OpenELEC vdr[3796]: [3857] creating new channel 'Fox Comedy HD,;Satlink' on S13.0E transponder 110853 with id 318-11700-5201-0
Jun 19 16:05:27 OpenELEC vdr[3796]: [3857] creating new channel 'Fox Animation HD,;Satlink' on S13.0E transponder 110853 with id 318-11700-5301-0
Jun 19 16:05:28 OpenELEC vdr[3796]: [3857] changing pids of channel 2316 (Fashiontv loriginal HD) from 0+0=0:0:0:0 to 2010+2010=27:2011=eng@4,2012=eng@4:0:0
Jun 19 16:05:28 OpenELEC vdr[3796]: [3857] changing caids of channel 2316 (Fashiontv loriginal HD) from 0 to 500
Jun 19 16:05:28 OpenELEC vdr[3796]: [3857] changing pids of channel 2318 (Fox Animation HD) from 0+0=0:0:0:0 to 5302+5302=27:0;5303=ita@106,5304=und@106:0:5305
Jun 19 16:05:28 OpenELEC vdr[3796]: [3857] changing caids of channel 2318 (Fox Animation HD) from 0 to 919,93B,9CD
Jun 19 16:05:30 OpenELEC vdr[3796]: [3857] changing pids of channel 2315 (Comedy Central Poland HD) from 0+0=0:0:0:0 to 1202+1202=27:1203=pol@4,1204=eng@4:0:0
Jun 19 16:05:30 OpenELEC vdr[3796]: [3857] changing caids of channel 2315 (Comedy Central Poland HD) from 0 to 500,100,1813,B01,1884,1803,1861
Jun 19 16:05:32 OpenELEC vdr[3796]: [4179] VNSI: exit streamer thread
Jun 19 16:05:32 OpenELEC vdr[3796]: [4179] cLiveStreamer stream processor thread ended (pid=3796, tid=4179)
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: LiveStreamer::Close - close
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: close video input ...
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: call retune ...
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: allocated timeshift buffer with size: 4000000000
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] CAM 2: assigned to device 2
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: Successfully found following device: 0x16f29c0 (2) for receiving
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] EEPG: setstatus 0
Jun 19 16:05:32 OpenELEC vdr[3796]: [4249] device 2 receiver thread started (pid=3796, tid=4249, prio=high)
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: Successfully switched to channel 2 - Sky Cinema+1 HD
Jun 19 16:05:32 OpenELEC vdr[3796]: [4177] VNSI: Started streaming of channel Sky Cinema+1 HD (timeout 10 seconds)
Jun 19 16:05:32 OpenELEC vdr[3796]: [4253] device 2 TS buffer thread started (pid=3796, tid=4253, prio=high)
Jun 19 16:05:32 OpenELEC vdr[3796]: [4251] cLiveStreamer stream processor thread started (pid=3796, tid=4251, prio=high)
Jun 19 16:05:32 OpenELEC vdr[3796]: [4250] VNSI: VideoInput: no pat/pmt within timeout, falling back to channel pids
Jun 19 16:05:32 OpenELEC vdr[3796]: [4250] VNSI: Video Input - new pmt, attaching receiver
Jun 19 16:05:32 OpenELEC vdr[3796]: [4250] DVBAPI: 1.0 set CAM decrypt (SID 134 (0x0086), caLm 4, HasCaDescriptors 0)
Jun 19 16:05:33 OpenELEC vdr[3796]: [4251] VNSI: Created stream for pid=255 and type=8
Jun 19 16:05:33 OpenELEC vdr[3796]: [4251] VNSI: Created stream for pid=259 and type=1
Jun 19 16:05:33 OpenELEC vdr[3796]: [4251] VNSI: Created stream for pid=260 and type=1
Jun 19 16:05:33 OpenELEC vdr[3796]: [4251] VNSI: Created stream for pid=32 and type=11
Jun 19 16:05:34 OpenELEC vdr[3796]: [3857] EEPG: setstatus 0
Jun 19 16:05:34 OpenELEC vdr[3796]: [3857] EEPG: setstatus 1
Jun 19 16:05:34 OpenELEC vdr[3796]: [3857] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 16:05:34 OpenELEC vdr[3796]: [3880] VNSI: Trigger EPG update for channel Baby TV, id: 1775723836
Jun 19 16:05:34 OpenELEC vdr[3796]: [3857] changing pids of channel 3 (Sky Cinema+24 HD) from 511+511=27:0;515=deu@106:0:32 to 511+511=27:0;515=deu@106,516=eng@106:0:32
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] retuning due to modification of channel 2 (Sky Cinema+1 HD)
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] switching to channel 2 (Sky Cinema+1 HD)
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] DVBAPI: 0.0 set CAM decrypt (SID 131 (0x0083), caLm 5, HasCaDescriptors 1)
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] CAM 1: unassigned
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] EEPG: setstatus 0
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] EEPG: setstatus 1
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 16:05:34 OpenELEC vdr[3796]: [3796] VNSI: re-tune to channel Sky Cinema+1 HD
Jun 19 16:05:34 OpenELEC vdr[3796]: [4251] VNSI: close video input ...
Jun 19 16:05:34 OpenELEC vdr[3796]: [4251] VNSI: call retune ...
Jun 19 16:05:34 OpenELEC vdr[3796]: [3895] device 1 TS buffer thread ended (pid=3796, tid=3895)
Jun 19 16:05:34 OpenELEC vdr[3796]: [3894] buffer stats: 126336 (2%) used
Jun 19 16:05:34 OpenELEC vdr[3796]: [3894] device 1 receiver thread ended (pid=3796, tid=3894)
Jun 19 16:05:34 OpenELEC vdr[3796]: [4251] VNSI: Successfully found following device: 0x16f29c0 (2) for receiving
Jun 19 16:05:34 OpenELEC vdr[3796]: [4251] EEPG: setstatus 0
Jun 19 16:05:34 OpenELEC vdr[3796]: [4251] EEPG: setstatus 1
Jun 19 16:05:34 OpenELEC vdr[3796]: [4251] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 16:05:34 OpenELEC vdr[3796]: [4258] VNSI: VideoInput: no pat/pmt within timeout, falling back to channel pids
Jun 19 16:05:34 OpenELEC vdr[3796]: [4258] VNSI: Video Input - new pmt, attaching receiver
Jun 19 16:05:35 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:36 OpenELEC vdr[3796]: [3857] EEPG: PMT scan idle
Jun 19 16:05:36 OpenELEC vdr[3796]: [3857] EEPG: Ended all processing
Jun 19 16:05:36 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:37 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:38 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:39 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:40 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:41 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:42 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:42 OpenELEC vdr[3796]: [3857] creating new channel 'Sky Bundesliga HD 7,Sky BuliHD 7;SKY' on S19.2E transponder 111552 with id 133-8-317-0
Jun 19 16:05:42 OpenELEC vdr[3796]: [3857] creating new channel 'Sky Sport HD 8,SportHD 8;SKY' on S19.2E transponder 111552 with id 133-8-318-0
Jun 19 16:05:42 OpenELEC vdr[3796]: [3857] creating new channel 'Eurosport360HD 6,Eurosp360 6;SKY' on S19.2E transponder 111552 with id 133-8-320-0
Jun 19 16:05:42 OpenELEC vdr[3796]: [4251] VNSI: Channel: startcode 5
Jun 19 16:05:43 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:44 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:45 OpenELEC vdr[3796]: [3880] VNSI: Trigger EPG update for channel Baby TV, id: 1775723836
Jun 19 16:05:45 OpenELEC vdr[3796]: [3880] VNSI: Trigger EPG update for channel Sky Bundesliga HD 7, id: 1521840357
Jun 19 16:05:46 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:47 OpenELEC vdr[3796]: [3796] EEPG: setstatus 0
Jun 19 16:05:47 OpenELEC vdr[3796]: [3856] frontend 1/0 lost lock on channel 2 (Sky Cinema+1 HD), tp 111552
Jun 19 16:05:48 OpenELEC vdr[3796]: [4249] ERROR: skipped 132 bytes to sync on TS packet on device 2
Jun 19 16:05:48 OpenELEC vdr[3796]: [4249] ERROR: skipped 56 bytes to sync on TS packet on device 2
Jun 19 16:05:48 OpenELEC vdr[3796]: [4249] ERROR: skipped 251 bytes to sync on TS packet on device 2
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] EEPG: setstatus 0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] EEPG: setstatus 1
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 16:05:48 OpenELEC vdr[3796]: [4249] ERROR: skipped 62 bytes to sync on TS packet on device 2
Jun 19 16:05:48 OpenELEC vdr[3796]: [4249] ERROR: skipped 63 bytes to sync on TS packet on device 2
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+,;nc+' on S13.0E transponder 110892 with id 318-11900-4801-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+ FILM,;nc+' on S13.0E transponder 110892 with id 318-11900-4802-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+ SERIALE,;nc+' on S13.0E transponder 110892 with id 318-11900-4803-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'Kuchnia+,;nc+' on S13.0E transponder 110892 with id 318-11900-4804-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'Ale kino+,;nc+' on S13.0E transponder 110892 with id 318-11900-4805-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'teleTOON+,;nc+' on S13.0E transponder 110892 with id 318-11900-4806-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'TVP 1,;nc+' on S13.0E transponder 110892 with id 318-11900-4807-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'TVP 2,;nc+' on S13.0E transponder 110892 with id 318-11900-4808-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [4249] ERROR: skipped 78 bytes to sync on TS packet on device 2
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+ SPORT,;nc+' on S13.0E transponder 110892 with id 318-11900-4809-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'Domo+,;nc+' on S13.0E transponder 110892 with id 318-11900-4811-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel '4823,;nc+' on S13.0E transponder 110892 with id 318-11900-4823-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'H test 1,;nc+' on S13.0E transponder 110892 with id 318-11900-4830-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'H test 2,;nc+' on S13.0E transponder 110892 with id 318-11900-4831-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'H test 3,;nc+' on S13.0E transponder 110892 with id 318-11900-4832-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+ FILM,;nc+' on S13.0E transponder 110892 with id 318-11900-4833-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+,;nc+' on S13.0E transponder 110892 with id 318-11900-4835-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+ SPORT,;nc+' on S13.0E transponder 110892 with id 318-11900-4837-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'NC+ RMF,;nc+' on S13.0E transponder 110892 with id 318-11900-4842-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+,;nc+' on S13.0E transponder 110892 with id 318-11900-4851-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'CANAL+ SPORT,;nc+' on S13.0E transponder 110892 with id 318-11900-4853-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'Ale kino+,;nc+' on S13.0E transponder 110892 with id 318-11900-4855-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'DTV CABLE KU,;nc+' on S13.0E transponder 110892 with id 318-11900-4874-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'DTV CABLE AL,;nc+' on S13.0E transponder 110892 with id 318-11900-4875-0
Jun 19 16:05:48 OpenELEC vdr[3796]: [3853] creating new channel 'DTV CABLE TT,;nc+' on S13.0E transponder 110892 with id 318-11900-4876-0
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2345 (DTV CABLE TT) from 0+0=0:0:0:0 to 165+165=2:100=pol@4:0:0
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2345 (DTV CABLE TT) from 0 to 100
Jun 19 16:05:49 OpenELEC vdr[3796]: [4249] ERROR: skipped 110 bytes to sync on TS packet on device 2
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2340 (CANAL+) from 0+0=0:0:0:0 to 160+160=2:80=pol@4,81=eng@4:710=pol:500
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2340 (CANAL+) from 0 to 100
Jun 19 16:05:49 OpenELEC vdr[3796]: [4249] ERROR: skipped 98 bytes to sync on TS packet on device 2
Jun 19 16:05:49 OpenELEC vdr[3796]: [4249] ERROR: skipped 85 bytes to sync on TS packet on device 2
Jun 19 16:05:49 OpenELEC vdr[3796]: [4249] ERROR: skipped 5 bytes to sync on TS packet on device 2
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2323 (CANAL+ FILM) from 0+0=0:0:0:0 to 161+161=2:84=pol@4,85=ORY@4;86=ORY@106:711=pol:500
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2323 (CANAL+ FILM) from 0 to 100,1813,B01
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2325 (Kuchnia+) from 0+0=0:0:0:0 to 163+163=2:92=pol@4:0:0
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2325 (Kuchnia+) from 0 to 100,1813,B01,B00
Jun 19 16:05:49 OpenELEC vdr[3796]: [4249] ERROR: skipped 188 bytes to sync on TS packet on device 2
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2327 (teleTOON+) from 0+0=0:0:0:0 to 165+165=2:100=pol@4:0:0
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2327 (teleTOON+) from 0 to 100,1813,B01,B00
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2328 (TVP 1) from 0+0=0:0:0:0 to 166+166=2:104=pol@4,105=pol@4:0:503
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2328 (TVP 1) from 0 to 100,1813,500,B00,B01,1803,1861
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2329 (TVP 2) from 0+0=0:0:0:0 to 167+167=2:108=pol@4,109=pol@4:0:508
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2329 (TVP 2) from 0 to 100,1813,500,B00,B01,1803,1861
Jun 19 16:05:49 OpenELEC vdr[3796]: [3856] frontend 1/0 timed out while tuning to channel 2 (Sky Cinema+1 HD), tp 111552
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2330 (CANAL+ SPORT) from 0+0=0:0:0:0 to 168+168=2:112=pol@4:0:500
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2330 (CANAL+ SPORT) from 0 to 100,1813,B01
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2332 (4823) from 0+0=0:0:0:0 to 168+168=2:114=AU1@4:0:0
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2332 (4823) from 0 to 100
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing pids of channel 2334 (H test 2) from 0+0=0:0:0:0 to 161+161=2:85=eng@4:711=pol:500
Jun 19 16:05:49 OpenELEC vdr[3796]: [3853] changing caids of channel 2334 (H test 2) from 0 to 100
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing pids of channel 2335 (H test 3) from 0+0=0:0:0:0 to 168+168=2:112=pol@4:0:500
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing caids of channel 2335 (H test 3) from 0 to 100
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing pids of channel 2336 (CANAL+ FILM) from 0+0=0:0:0:0 to 161+161=2:84=pol@4,85=ory@4:711=pol:500
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing caids of channel 2336 (CANAL+ FILM) from 0 to 100
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing pids of channel 2337 (CANAL+) from 0+0=0:0:0:0 to 160+160=2:80=pol@4,81=org@4:710=pol:500
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing caids of channel 2337 (CANAL+) from 0 to 100
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing pids of channel 2338 (CANAL+ SPORT) from 0+0=0:0:0:0 to 168+168=2:112=pol@4:0:500
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing caids of channel 2338 (CANAL+ SPORT) from 0 to 100
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing pids of channel 2339 (NC+ RMF) from 0+0=0:0:0:0 to 0+0=0:137=RMF@4,138=MAX@4,139=CLA@4:0:0
Jun 19 16:05:50 OpenELEC vdr[3796]: [3853] changing caids of channel 2339 (NC+ RMF) from 0 to 1813,1884,B01,100
Jun 19 16:05:50 OpenELEC vdr[3796]: [3856] frontend 1/0 regained lock on channel 2 (Sky Cinema+1 HD), tp 111552
Jun 19 16:05:50 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:51 OpenELEC vdr[3796]: [3853] changing pids of channel 1075 (teleTOON+) from 0+0=0:0:0:0 to 165+165=2:100=pol@4:0:0
Jun 19 16:05:51 OpenELEC vdr[3796]: [3853] changing caids of channel 1075 (teleTOON+) from 0 to 1813,100,B00
Jun 19 16:05:51 OpenELEC vdr[3796]: [3853] changing pids of channel 2343 (DTV CABLE KU) from 0+0=0:0:0:0 to 163+163=2:92=pol@4:0:0
Jun 19 16:05:51 OpenELEC vdr[3796]: [3853] changing caids of channel 2343 (DTV CABLE KU) from 0 to 100
Jun 19 16:05:51 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:51 OpenELEC vdr[3796]: [3880] VNSI: Requesting clients to reload channel list
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing pids of channel 2322 (CANAL+) from 0+0=0:0:0:0 to 160+160=2:80=pol@4,81=ORY@4:710=pol:500
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing caids of channel 2322 (CANAL+) from 0 to 100,1813,B01
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing pids of channel 2324 (CANAL+ SERIALE) from 0+0=0:0:0:0 to 162+162=2:88=pol@4:0:500
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing caids of channel 2324 (CANAL+ SERIALE) from 0 to 100,1813,B01
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing pids of channel 2326 (Ale kino+) from 0+0=0:0:0:0 to 164+164=2:96=pol@4,97=ORY@4:715=pol:500
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing caids of channel 2326 (Ale kino+) from 0 to 100,1813,B01,B00
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing pids of channel 2331 (Domo+) from 0+0=0:0:0:0 to 170+170=2:316=pol@4:0:0
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing caids of channel 2331 (Domo+) from 0 to 100,1813,B01,B00
Jun 19 16:05:52 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:52 OpenELEC vdr[3796]: [4251] VNSI: Channel: scrambled 7
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing pids of channel 2333 (H test 1) from 0+0=0:0:0:0 to 160+160=2:81=eng@4:710=pol:500
Jun 19 16:05:52 OpenELEC vdr[3796]: [3853] changing caids of channel 2333 (H test 1) from 0 to 100
Jun 19 16:05:53 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:54 OpenELEC vdr[3796]: [3853] changing pids of channel 1074 (Kuchnia+) from 0+0=0:0:0:0 to 163+163=2:92=@4:0:0
Jun 19 16:05:54 OpenELEC vdr[3796]: [3853] changing caids of channel 1074 (Kuchnia+) from 0 to B01,100,1813,B00
Jun 19 16:05:54 OpenELEC vdr[3796]: [3853] EEPG: PMT scan idle
Jun 19 16:05:54 OpenELEC vdr[3796]: [3853] EEPG: Ended all processing
Jun 19 16:05:55 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:56 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:56 OpenELEC vdr[3796]: [3880] VNSI: Trigger EPG update for channel Kuchnia+, id: 1691841363
Jun 19 16:05:57 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:58 OpenELEC vdr[3796]: [4251] VNSI-Error: cParser::AddPESPacket - max buffer size reached, pid: 255
Jun 19 16:05:58 OpenELEC vdr[3796]: [3853] changing pids of channel 2344 (DTV CABLE AL) from 0+0=0:0:0:0 to 164+164=2:96=pol@4,97=eng@4:715=pol:500
Jun 19 16:05:58 OpenELEC vdr[3796]: [3853] changing caids of channel 2344 (DTV CABLE AL) from 0 to 100
I think the issue is related to this message: "retuning due to modification of channel 2"
This can only happen if there is a primary device with a decoder. Either you have a full featured card with its own decoder or some other plugin pretends to be one. What other plugins other dvbapi you you have loaded? can you try to disable those to find the culprit?
beside the plug-ins streamdev-server & live plug-in, which is now disabled the dummy-device is acticting as a primary device. So far i will need this otherwise the current live streaming would be remove the current tuner when a
recording is started. ("headless config")
i have 2 usb tuners installed. no one is actually able to run as a full featured card.
plug-ins which are running:
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-dvbapi.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-wirbelscan.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-wirbelscancontrol.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-eepg.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-epgsearch.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-dummydevice.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-restfulapi.so.2.2.0
problem still exist.
here the start log:
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] VDR version 2.2.0 started
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] switched to user 'root'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] codeset is 'UTF-8' - known
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] use of environment variable VDR_CHARSET_OVERRIDE (iso-8859-15) is deprecated!
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] override character table is 'iso-8859-15'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] ERROR (tools.c,1529): /usr/share/locale: No such file or directory
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'deu,ger'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'slv,slo'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'ita'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'dut,nla,nld'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'prt'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'fra,fre'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'nor'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'fin,suo'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'pol'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'esl,spa'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'ell,gre'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'sve,swe'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'rom,rum'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'hun'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'cat,cln'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'rus'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'srb,srp,scr,scc'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'hrv'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'est'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'dan'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'cze,ces'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'tur'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'ukr'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] no locale for language code 'ara'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] cTimeMs: using monotonic clock (resolution is 1 ns)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: Port has been set to 8002!
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: Ip has been set to 0.0.0.0!
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: trying to parse command line arguments
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: The EPG-Images will be loaded from /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/epgimages!
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: The Channel-Logos will be loaded from /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/channellogos!
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] RESTful-API Settings: port: 8002, ip: 0.0.0.0, eimgs: /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/epgimages, cimgs: /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/channellogos, webapp: , headers: activated
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading plugin: /storage/.kodi/addons/service.multimedia.vdr-addon/plugin/libvdr-vnsiserver.so.2.2.0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/setup.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/sources.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/diseqc.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/scr.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/channels.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/timers.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/svdrphosts.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/remote.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/keymacros.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] registered source parameters for 'A - ATSC'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] registered source parameters for 'C - DVB-C'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3611] epg data reader thread started (pid=3557, tid=3611, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3610] video directory scanner thread started (pid=3557, tid=3610, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] registered source parameters for 'S - DVB-S'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] registered source parameters for 'T - DVB-T'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3611] reading EPG data from /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/cache/epg.data
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] probing /dev/dvb/adapter0/frontend0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] creating cDvbDevice
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] new device number 1
Jun 19 20:01:20 OpenELEC vdr[3557]: [3609] video directory scanner thread started (pid=3557, tid=3609, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVB API version is 0x050A (VDR was built with 0x050A)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] frontend 0/0 provides DVB-S,DVB-S2 with QPSK ("Montage M88DS3103")
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] probing /dev/dvb/adapter1/frontend0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] new device number 2
Jun 19 20:01:20 OpenELEC vdr[3557]: [3614] device 1 section handler thread started (pid=3557, tid=3614, prio=low)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3613] frontend 0/0 tuner thread started (pid=3557, tid=3613, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] frontend 1/0 provides DVB-S,DVB-S2 with QPSK ("Montage M88DS3103")
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] found 2 DVB devices
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: dvbapi (2.2.0): SoftCAM for OSCam
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: wirbelscan (0.0.9): DVB and pvrinput channel scan for VDR
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: wirbelscancontrol (0.0.2): scan channels using wirbelscan
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: eepg (0.0.6pre): Parses Extended EPG data
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: epgsearch (1.0.1.beta5): search the EPG for repeats and more
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: dummydevice (2.0.0): Output device that does nothing
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] new device number 3
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: restfulapi (0.2.1.4): Offers a RESTful-API to retrieve data from VDR
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] initializing plugin: vnsiserver (1.3.0): VDR-Network-Streaming-Interface (VNSI) Server
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] setting primary device to 3
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] assuming manual start of VDR
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] SVDRP listening on port 6419
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] setting current skin to "sttng"
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/themes/sttng-default.theme
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: dvbapi
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: plugin version 2.2.0 initializing (VDR 2.2.0)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: decryption library: libdvbcsa
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: Creating sCCIAdapter for device 0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: Creating sCCIAdapter for device 1
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: plugin started
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: wirbelscan
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: wirbelscancontrol
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: eepg
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] Attached EEPG filter to device 0
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] Attached EEPG filter to device 1
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] Attached EEPG filter to device 2
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] EEPG: Warning, not found equivalent channel 'T-272-905-143' in channels.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] EEPG: Warning, not found equivalent channel 'T-272-905-142' in channels.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: epgsearch
Jun 19 20:01:20 OpenELEC vdr[3557]: [3619] SC-CI adapter on device 0 thread started (pid=3557, tid=3619, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3620] SC-CI adapter on device 1 thread started (pid=3557, tid=3620, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3617] device 2 section handler thread started (pid=3557, tid=3617, prio=low)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] EPGSearch: loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/plugins/epgsearch/epgsearch.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/plugins/epgsearch/timersdone.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3618] Socket Handler thread started (pid=3557, tid=3618, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3616] frontend 1/0 tuner thread started (pid=3557, tid=3616, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: dummydevice
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: restfulapi
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: Used settings: port: 8002, ip: 0.0.0.0, eimgs: /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/epgimages, cimgs: /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/channellogos, webapp: , headers: activated
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: found 0 files in /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/epgimages/*.
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: found 0 files in /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/channellogos/*.
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: Initializing inotify for /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/epgimages finished.
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] restfulapi: Initializing inotify for /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/channellogos finished.
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] create server
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] starting plugin: vnsiserver
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] VNSI: Starting vnsi server at port=34890
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] VNSI: VNSI Server started
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] VNSI: Channel streaming timeout: 10 seconds
Jun 19 20:01:20 OpenELEC vdr[3557]: [3625] VDR VNSI Server thread started (pid=3557, tid=3625, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3621] EPGSearch: conflictcheck thread started (pid=3557, tid=3621, prio=high)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3626] VNSI: Recordings state changed (11)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3626] VNSI: Requesting clients to reload recordings list
Jun 19 20:01:20 OpenELEC vdr[3557]: [3619] DVBAPI: 0.0: doReply changed, reset triggered
Jun 19 20:01:20 OpenELEC vdr[3557]: [3619] DVBAPI: 0.0: now using CAIDs version 1
Jun 19 20:01:20 OpenELEC vdr[3557]: [3619] DVBAPI: 0.0: status 'present'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3619] CAM 1: module present
Jun 19 20:01:20 OpenELEC vdr[3557]: [3625] loading /storage/.kodi/userdata/addon_data/service.multimedia.vdr-addon/config/plugins/vnsiserver/allowed_hosts.conf
Jun 19 20:01:20 OpenELEC vdr[3557]: [3625] VNSI: Client with ID 0 connected: 127.0.0.1:47407
Jun 19 20:01:20 OpenELEC vdr[3557]: [3635] VNSI: Welcome client 'XBMC Media Center' with protocol version '8'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: 1.0: doReply changed, reset triggered
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: 1.0: now using CAIDs version 1
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: 1.0: status 'present'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: 0.0: status 'reset'
Jun 19 20:01:20 OpenELEC vdr[3557]: [3626] VNSI: Requesting clients to reload channel list
Jun 19 20:01:20 OpenELEC vdr[3557]: [3626] VNSI: Recordings state changed (25)
Jun 19 20:01:20 OpenELEC vdr[3557]: [3557] DVBAPI: 1.0: status 'reset'
Jun 19 20:01:21 OpenELEC vdr[3557]: [3557] DVBAPI: 0.0: status 'ready'
Jun 19 20:01:21 OpenELEC vdr[3557]: [3620] DVBAPI: 1.0: status 'ready'
Jun 19 20:01:21 OpenELEC vdr[3557]: [3620] CAM 2: module ready
Jun 19 20:01:21 OpenELEC vdr[3557]: [3619] CAM 1: module ready
Jun 19 20:01:21 OpenELEC vdr[3557]: [3620] DVBAPI: CaInfo: 1.0 sending CA info
Jun 19 20:01:21 OpenELEC vdr[3557]: [3620] CAM 2: system ids: FFFF
Jun 19 20:01:21 OpenELEC vdr[3557]: [3619] DVBAPI: CaInfo: 0.0 sending CA info
Jun 19 20:01:21 OpenELEC vdr[3557]: [3619] CAM 1: system ids: FFFF
Jun 19 20:01:21 OpenELEC vdr[3557]: [3626] VNSI: Recordings state changed (45)
Jun 19 20:01:21 OpenELEC vdr[3557]: [3626] VNSI: Requesting clients to reload recordings list
Jun 19 20:01:21 OpenELEC vdr[3557]: [3610] video directory scanner thread ended (pid=3557, tid=3610)
Jun 19 20:01:21 OpenELEC vdr[3557]: [3609] video directory scanner thread ended (pid=3557, tid=3609)
Jun 19 20:01:21 OpenELEC vdr[3557]: [3626] VNSI: Recordings state changed (92)
Jun 19 20:01:22 OpenELEC vdr[3557]: [3620] CAM 2: replies to QUERY - multi channel decryption possible
Jun 19 20:01:22 OpenELEC vdr[3557]: [3619] CAM 1: replies to QUERY - multi channel decryption possible
Jun 19 20:01:22 OpenELEC vdr[3557]: [3557] switching to channel 1 (Sky Cinema HD)
Jun 19 20:01:22 OpenELEC vdr[3557]: [3611] epg data reader thread ended (pid=3557, tid=3611)
Jun 19 20:01:22 OpenELEC vdr[3557]: [3557] CAM 1: assigned to device 1
Jun 19 20:01:22 OpenELEC vdr[3557]: [3557] DVBAPI: 0.0 set CAM decrypt (SID 131 (0x0083), caLm 4, HasCaDescriptors 0)
Jun 19 20:01:22 OpenELEC vdr[3557]: [3639] device 1 receiver thread started (pid=3557, tid=3639, prio=high)
Jun 19 20:01:22 OpenELEC vdr[3557]: [3640] device 1 TS buffer thread started (pid=3557, tid=3640, prio=high)
Jun 19 20:01:22 OpenELEC vdr[3557]: [3557] OSD size changed to 720x480 @ 1
Jun 19 20:01:22 OpenELEC vdr[3557]: [3557] timer 1 (4 2100-2202 'House of Cards') set to event Fri 19.06.2015 21:00-22:00 'Olive Kitteridge'
Jun 19 20:01:22 OpenELEC vdr[3557]: [3621] EPGSearch: timer conflict check started
Jun 19 20:01:22 OpenELEC vdr[3557]: [3621] timer 1 (4 2100-2202 'House of Cards') set to event Fri 19.06.2015 21:00-22:00 'Olive Kitteridge'
Jun 19 20:01:22 OpenELEC vdr[3557]: [3621] EPGSearch: timer conflict check finished
Jun 19 20:01:23 OpenELEC vdr[3557]: [3614] EEPG: setstatus 0
Jun 19 20:01:23 OpenELEC vdr[3557]: [3614] EEPG: setstatus 1
Jun 19 20:01:23 OpenELEC vdr[3557]: [3614] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 20:01:23 OpenELEC vdr[3557]: [3614] EEPG: PMT scan idle
Jun 19 20:01:23 OpenELEC vdr[3557]: [3614] EEPG: Ended all processing
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] retuning due to modification of channel 1 (Sky Cinema HD)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] switching to channel 1 (Sky Cinema HD)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] DVBAPI: 0.0 set CAM decrypt (SID 131 (0x0083), caLm 5, HasCaDescriptors 1)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] CAM 1: unassigned
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] CAM 1: assigned to device 1
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] EEPG: setstatus 0
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] EEPG: setstatus 1
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] EEPG: Filter Pid:0,Tid:0 added.
Jun 19 20:01:24 OpenELEC vdr[3557]: [3557] DVBAPI: 0.0 set CAM decrypt (SID 131 (0x0083), caLm 4, HasCaDescriptors 1)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3640] device 1 TS buffer thread ended (pid=3557, tid=3640)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3639] buffer stats: 94940 (1%) used
Jun 19 20:01:24 OpenELEC vdr[3557]: [3639] device 1 receiver thread ended (pid=3557, tid=3639)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3647] device 1 receiver thread started (pid=3557, tid=3647, prio=high)
Jun 19 20:01:24 OpenELEC vdr[3557]: [3648] device 1 TS buffer thread started (pid=3557, tid=3648, prio=high)
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] EEPG: PMT scan idle
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] EEPG: Ended all processing
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] creating new channel 'Sky Bundesliga HD 2,Sky BuliHD 2;SKY' on S19.2E transponder 111914 with id 133-6-267-0
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] creating new channel 'Eurosport360HD 1,Eurosp360 1;SKY' on S19.2E transponder 111914 with id 133-6-270-0
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] creating new channel 'Sky Sport HD 3,SportHD 3;SKY' on S19.2E transponder 111914 with id 133-6-268-0
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] creating new channel 'Sky Sport HD 1,SportHD 1;SKY' on S19.2E transponder 111914 with id 133-6-129-0
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] changing pids of channel 2243 (Sky Sport HD 1) from 0+0=0:0:0:0 to 767+767=27:0;770=deu@106,771=deu@106,772=deu@106:0:32
Jun 19 20:01:25 OpenELEC vdr[3557]: [3614] changing caids of channel 2243 (Sky Sport HD 1) from 0 to 1833,9C4,9AF,98C
Jun 19 20:01:31 OpenELEC vdr[3557]: [3626] VNSI: Trigger EPG update for channel Romance TV, id: 1983487117
Jun 19 20:01:31 OpenELEC vdr[3557]: [3626] VNSI: Trigger EPG update for channel Spiegel Geschichte HD, id: 1795671561
Jun 19 20:01:31 OpenELEC vdr[3557]: [3626] VNSI: Trigger EPG update for channel SIXX, id: 74550168
Jun 19 20:01:31 OpenELEC vdr[3557]: [3626] VNSI: Trigger EPG update for channel BB-MV Lokal-TV, id: 1959619371
when dummy-device is disabled problem is gone. Is vnsi-server acting as primary device too?
why do you need this dummy device?
vnsiserver can started with option -d. then it acts as primary device when vdr ui is active. this makes femon work. I am not aware of any other use cases requiring a primary device.
as far i can remember i was need this dummy device otherwise the selecting of the two usb tuner doesn't work right in conjunction with recordings. this was until now the case or the dummy device didn't have made any issues until mid/end may. I was running this configuration from one year ago.
Quote:Dieses Plugin wird für Rechner benötigt, die als reiner Aufnahmeserver mit Budget Karten laufen sollen. Es wird hier nichts gestreamt oder dergleichen. Daher gibt es auch kein Livebild. Der Aufnahmeserver kann dann über vdradmin oder das remoteplugin ferngesteuert werden. Die Aufnahmen kann man sich dann über NFS mounten und einem Client zur Verfügung stellen.
Für vdr 1.4.x ist das Plugin zwar empfohlen aber nicht zwingend notwendig. Ohne dummydevice wird einfach eine der Budget Karten zum Ausgabegerät erklärt, auch wenn tatsächlich nichts ausgeben werden kann. Beim Kanalwechsel über SVDRP kann dies jedoch zu Problemen führen. SVDRP schaltet grundsätzlich den Kanal des Ausgabegeräts. Ist dieses aber zur Zeit belegt, schlägt der Kanalwechsel fehl - selbst wenn eine andere Budget-Karte frei wäre.
this was actually my issue.
btw: vnsi server is not started with "-d"
if this is all I would drop the dummy device. the mentioned SVDRP issue is similar to the femon issue I mentioned. vdr refuses to change channel in this case. when vnsiserver is started with -d it ONLY acts as primary device when client specific vdr ui is active. if not in this dialog, it does not because of exactly those kind of issues.
anyway, with my changes of today you can continue to use dummy device
Okay thank you. If i would not had these tuner issues i would never activate the dummy device. But the vdr have this primary device structure. I think this is a historical feature. When i get your changes i will report back.
