2015-06-21, 20:19
I'm using FileBot to auto rename my folders/files to fit a certain naming format. Examples:
But when using TMM it's detecting the movies as So whenever i have it scrape data i have to manually remove the '1920x800 24 000fps & foreign name' parts from the name or else it will come up with no results.
Is there something that can be done to avoid this? (Besides switching to a different naming format)
Guessing this has something to do with the way TMM gets the name of the movie to search for.
I'm using the latest 2.6.8 (r2052) version of TMM.
edit: I've also noticed it's having issues with certain characters in a file name.
When there is either an é or anything with the ' (i.e. You're) it shows no results until you delete that character.
Might be more but these are the ones i've run into.
H:\Gemma Bovery (2014)\Gemma.Bovery.2014.[1920x800].24.000fps.1080p.BRRip.x264.JYK.mkv
H:\In The Realm Of The Senses (1976) - 愛のコリーダ\Ai.No.Korīda.1976.[1280x772].23.976fps.720p.x264.CiNEFiLE.mkv
Gemma Bovery 1920x800 24 000fps
In The Realm Of The Senses □□□□□□
