2015-06-22, 16:25
I just started to use mediaportal as a backend for the kodi pvr.
For me it's not possible to view recordings in kodi.
I use a drivepool (from covecube) on my pvr server. Installation of the mediaportal back-end was no problem. But I wasn't able to set-up the plugin from magro (that wil connect to Kodi).
The pad for the recordings is red (until i set the pad on a harddrive and not on the drivepool). The timeshift is no problem because it's on a separated SSD.
When in Kodi, It's possible to set a recording, the back-end make's the actual recording, buts it's impossible to view the recording. Kodi gives รก no acces error.
Is it possible to use the plugin from magro on a drivepool or is this simply impossible? (I didn't provide logs from kodi because the problem is not with kodi, but with the plugin from magro)
