Hello,
Is there anyway to get that little blue scroll bar to show up in the "Favorites" menu?
That is a handy thing when using a Mouse.
Once again.... mouse is not yet supported in Metropolis.
You will find lots of things that don't work. It's just not supported (yet).
(2015-06-22, 19:27)jingai Wrote: [ -> ]Once again.... mouse is not yet supported in Metropolis.
I understand
Keep up the great work!!!
Fixed it anyway for continuity. (In the menu-refactor fork)
I will try to fix things as I can, but the mouse is still not officially supported so I will try to add fixes as long as they don't mess with Metropolis visually.
I think the best way to not flood the WIP with mouse issues is to maybe start a "Future mouse support" thread, and I will try to keep up.
Jingai, should I wait until you get a chance to merge the menu-refactor fork into the master? Can you merge mouse fixes off the menu-refactor branch easier, or should I build them off the official?
Cool Thanks MacGyver
Is there a file I need to add to enable the scroll bar in the favorite menu?
(2015-06-23, 22:56)gate1975mlm Wrote: [ -> ]Cool Thanks MacGyver
This one, in 720p. Overwrite the existing.
Ideally you'd create a new branch for each new 'feature'.
