Full Version: How do you run Cinema Experience if it's not already integrated into your skin?
I'm not using any of these skins. Is there any way to manually integrate into my skin?
Quote:Skins that have built-in integration:
Transparency! - http://forum.xbmc.org/showthread.php?tid=82435 http://forum.xbmc.org/showthread.php?tid=83643
Night - http://forum.xbmc.org/showthread.php?tid=82628
The Carmichael - http://forum.xbmc.org/showthread.php?tid=84970
Neon - http://forum.xbmc.org/showthread.php?tid=83337
Night Purity - http://forum.xbmc.org/showthread.php?tid=86753
Alaska Revisited - http://forum.xbmc.org/showthread.php?tid=87399
Backrow - http://forum.xbmc.org/showthread.php?tid=63773 - http://forum.xbmc.org/showthread.php?tid=87387You will need to disable 'Enable Music Now Playing Screen' in Skin Options
Aeon MQ 2 - http://forum.xbmc.org/showthread.php?tid=81601
Cirrus Extended - http://forum.xbmc.org/showthread.php?tid=90693
Metropolis - http://forum.xbmc.org/forumdisplay.php?fid=162
Any others, please post so I can add to this message
