Full Version: Can't get channels in Kodi
Just set up a new PC and can not get channels in Kodi.
All channels work fine in WMC.
All set up the same as my previous PC, had no issues there.
http://pastebin.com/YzAmEbA3
Help please.
Doug
Your ServerWMC log doesn't show any client connecting, what settings are you using on the client side? Does the pvr addon start? Perhaps a Kodi debug log will help
sometimes when I go into Live TV I receive a message that the PVR client has not started.
other times it has started but the channel list and EPG are empty.
In settings it is the only pvr addon installed, it is enabled, i have IP set, port 9080, wake on LAN off, store resume status on, enable status signal calls off, refresh interval 10s.
Kodi log:
http://pastebin.com/8FgM4NrP
it is now working.
was a network problem, IP address kept resetting.
scarecorw420 sorry to waste your time.
Not a waste at all, sometimes you just need prompting to poke into log files and try different things etc Smile glad it's now working!
