I have run into an interesting issue. Running latest version of Rapier and Kodi RC1. After the system sleeps for a few hours, when I try to use it, the screens overlap with what looks like the bottom menu sliding over a frozen graphic. Usually I will have to reboot.Not sure how to insert an image in this text.
Is anyone seeing something similar?
Rob
Hi Rob.
Can you please try Confluence to see if the same problem occurs?
Which platform and specs do you run?
To insert an image, use this code:
[img]http://www.link.to.your.image.png[/img]
Cheers
Gade
It has not done it in either Confluence or Aeon MQ6.
Running Intel i5 3.4 ghz, tons of ram Win 7, Kodi 15 RC2, Rapier 8.1.5
It only started when I went to 8.1.5. I have tried replacing the entire folder, still have the issue. Can I e-mail you the screen shot as I don't have a web server to point at for you.
Rob
That's very weird.
You can upload images to
http://tinypic.com/ for free without an account.
I will look into it when you have time to upload an image
That looks strange. I have never experienced anything like this.
Going from 8.1.3 to 8.1.5 shouldn't have anything to do with this.
Could you try updating to 8.2.0
from my repo and let me know if the issue continues?
If it does, can you post a
debug log when this happens?
OK, I've installed 8.2.0. I'll let you know how it goes..
