2015-07-11, 19:14
Pages: 1 2
2015-07-11, 19:17
Can you explain what you mean by that question?
2015-07-11, 19:21
Hey Piers , you know how Aeon Nox movie Info looks like , something like that http://tinypic.com/r/el6vex/8
2015-07-11, 19:28
(2015-07-11, 19:21)Karnage11 Wrote: [ -> ]Hey Piers , you know how Aeon Nox movie Info looks like , something like that http://tinypic.com/r/el6vex/8
That's skin-specific. Aeon Nox looks like that, Xperience1080 looks like it does as present.
2015-07-11, 19:30
i know what you mean , don't get me wrong i like the way you made Xperience1080 , i just like the movie info layout with Aeon Nox
2015-07-11, 19:33
(2015-07-11, 19:30)Karnage11 Wrote: [ -> ]i know what you mean i like Xperience1080 how it is , i just like the movie info layout with Aeon Nox
You're welcome to send a PR on Github with the changes required... but the point of skins is that they look different from each other. That view can be integrated into Xperience1080, but it would take a few hours.
2015-07-11, 19:36
oh alright that' cool , not good on codec stuff at all anyways lol
2015-07-11, 19:37
i was just Mentioning that it that's all
2015-07-11, 19:47
(2015-07-11, 19:37)Karnage11 Wrote: [ -> ]i was just Mentioning that it that's all
If you'd like to create a proper mock-up for that screen, using Xperience1080 as a base, then I'd be happy to take a look.
A screenshot from Aeon Nox isn't enough - you'll need to add the correct colours and placing where you think it would fit within the same design of the skin.
2015-07-11, 19:50
how would i do that ?
2015-07-11, 19:53
Gimp or mspaint would do it. Just be a bit creative - then we can see how this skin would look with your feature and get a feeling of integration.
2015-07-11, 20:19
Is there anyway just to make it open like Extendedinfo does? Because the only way i can see it is when i click on extendedinfo itself
2015-07-11, 23:21
(2015-07-11, 20:19)Karnage11 Wrote: [ -> ]Is there anyway just to make it open like Extendedinfo does? Because the only way i can see it is when i click on extendedinfo itself
I don't understand. When you press 'I' on a movie, does it not display anything at all?
Please take screenshots of both the standard view and the extendedinfo view.
2015-07-11, 23:56
2015-07-12, 03:29
(2015-07-11, 23:56)komplex Wrote: [ -> ]I'm not sure but i think he means something like this as a view?
And not the normal view when you press "i"
I see. That's the default add-on design. Xperience1080 will not be changing to look like that, it simply wouldn't fit in with the rest of the skin.
Pages: 1 2
