On my Nexus 9, the re-Touched skin is hiding watched videos without the option being selected.
My watched videos are hidden and there is nothing I can do to see them except switch back to the default, not-so-tablet-friendly, skin.
thanx for the report.
i'll make sure it's fixed in the final version for kodi isengard.
LOL the opposite is now happening. Watched toggle now does nothing.
can't reproduce. it's working fine on my end.
The hide watched toggle makes no difference to the movie and tv shows list; both watched and unmatched are shown all the time.
Don't know what else to say.
Are you testing on Android?
Both my Nexus 9 and Windows desktop have the same version of Kodi and only the Nexus 9 has the issue. PC version works exactly as expected.
(2015-07-24, 06:53)mdh99 Wrote: [ -> ]Are you testing on Android?
nope...
which version of Re-Touched is running on your nexus?
(system > addons > my addons > skin > re-touced)
does the watched toggle work in Confluence on your nexus?
(2015-07-24, 10:06)ronie Wrote: [ -> ] (2015-07-24, 06:53)mdh99 Wrote: [ -> ]Are you testing on Android?
nope...
The Re-Touched skin version is 4.0.7 on both Windows and Android.
The watched toggled works in Confluence on both Windows and Android.
(2015-07-29, 03:51)mdh99 Wrote: [ -> ] (2015-07-24, 10:06)ronie Wrote: [ -> ] (2015-07-24, 06:53)mdh99 Wrote: [ -> ]Are you testing on Android?
nope...
Same problem here, button doesn't work.
Confluence is working normaly.
What I've just observed, checking it in both skins, is that:
1. If I hide watched episodes in confluence, when changing to re-touched it does not show watched episodes (works ok)
2. If I show watched episodes in confluence, when changing to re-touched it shows watched episodes (works ok)
3. If you chose to hide or show watched episodes in re-touched, it does take no effect, it keeps showing the view that showed in the first place (doesn't work)
So at my end and in short, re-touched reads the setting properly but does not set the setting properly.
Re-Touched 4.0.7
Kodi 15.1
IOS 8.1.2
Under linux it works ok though
Retouched 4.0.7
Kodi 15.1
Ubuntu 14.04.3 LTS
Linux 3.13.0-63-generic
(2015-09-15, 12:25)unelement Wrote: [ -> ] (2015-07-29, 03:51)mdh99 Wrote: [ -> ] (2015-07-24, 10:06)ronie Wrote: [ -> ]nope...
Re-Touched 4.0.7
Kodi 15.1
IOS 8.1.2
Under linux, it works ok though:
Re-Touched 4.0.7
Kodi 15.1
Ubuntu 14.04.3 LTS
Re-Touched 4.0.7
Kodi 15.1
IOS 8.1.2
Retouched 4.0.7
Kodi 15.1
Ubuntu 14.04.3 LTS
Exactly same problem here on Android 4.4.2, with Re-Touched 4.0.7 and Kodi 15.1.
