Full Version: Add or modify default Web interface files for testing JSON RPC Api
Hi all,
i am new here, i use one Raspberry Pi 2 and using OSMC, it is fantastic!
I would like to test JSON RPC Api calls using Ajax and i would like to modify or add some new html files to default web server interface but i don't know where i have to create .html files and directories and where "htdocs" files are on default web server interface.
Could you help me please?
Thanks in advance!
jps
Webinterfaces are plugins. i would recoment to make a new plugin rather than change the default one, so you don't get in troubles with updates....
I found directory using find command:
/usr/share/kodi/addons/webinterface.default
Modified htm files on this directory and web interface changes, all ok.
Thanks for your help
