2015-07-18, 13:28
2015-07-18, 13:29
How can i enable it?!
2015-07-18, 13:33
What language are you trying to use? What font is it that you are trying to use?
2015-07-19, 13:40
The font type is not the metter, the language is hebrew.
I have notice that the font line is in red, maby that the problem?
It dosent let me pres to change font? Or maby is the link that i downloaded the skin
2015-07-21, 08:19
The problem is that the fonts Metropolis is made with do not support Hebrew (or a lot of non-english character based languages). You can change the fonts to others that do, but it alters the look and spacing for menus.
I have created the most simple of fixes so that you can at least use Metropolis in your native language, but it will not look as nice or the same as the default Metropolis fonts that are used. (this fix just allows you to use the arial.ttf already built into Kodi)
It's here if Jingai wants a simple and flawed solution.
You can download the file directly from here, and copy it into your "skin.metropolis->720p" folder overwriting the existing one.
2015-10-01, 15:13
Thanks alot!
