Full Version: UK DVB Subtitles break with NextSubtitle
Hi, Just switched over from full MediaPortal to Kodi / MediaPortal, and loving it, channel switching is extremely fast, faster that with MediPortal.
My Question is to do with Subtitles for live TV, which seem a bit flaky. I have a satellite feed into MediaPortal server, so am receiving DVB-S and subtitles are defiantly present in the feed. By default subtitles are coming on, I can turn them off but bringing up info, going to subtitle button and switch from enable to disable, which turns them off, but if I go 'enable' again, they don't come back on, it seem a bit hit and mis. Am I doing something wrong?
I am on Kodi 15.0 RC2 Windows 7 64 bit.
Kind regards.
OK, I figured it out. DVB subtitles stop working if you use NextSubtitle:
1. Turn subtitles on with NextSubtitle
2. Turn subtitles off with NextSubtitle
3. Turn subtitles on with NextSubtitle
Subtitles no longer work, unless you stop the stream the re-tune.
OK, fixed it. I used 'showsubtitles' instead and now turns on and off absolutely fine.
