Full Version: Live TV top bar visibility
In Live TV how do I keep the top bar visible - the one that shows the channel and time?
I've disabled the 'Close channel OSD after switching channels' setting under 'Settings->Live TV->Menus/OSD' but that doesn't seem to do it.
The bar is visible when you press pause, info, or move the cursor.
It's not intended to be always shown.
Tgx
(2015-07-22, 12:36)Tgxcorporation Wrote: [ -> ]The bar is visible when you press pause, info, or move the cursor.
Tgx
Is it possible, though?
