Full Version: Changing scrollbar width in Comnfluence
I am building my own version of Kodi / OpenELEC for my RPi2 with Touchscreen. The touch works fine, but I have problems to hit small areas like a scrollbar. I am using Confluence becaus it has got a "close" button (the X) in the top right of dialogs.
Now my question: What do I have to do to make the change the scrollbar width ? I have found, that "scrollbar" is used in several XML files in Kodi\addons\skin.confluence\720p\. Do I just have to change the width property? What about the "graphic" from the scrollbar? Is there a graphic? If there is a texture I have to change, what do I have to do? How can I extract and compress the XBT file?
Best regards,
Rainer
look in 720p/Deafults.xml
Thank you
