Full Version: Crash when opening guide
On Ubuntu and just upgraded to 15. Everything seems to work but when I try to bring up the guide kodi crashes....
This is all the log gives me...
21:32:07 T:140667399374784 DEBUG: OnKey: 169 (0xa9) pressed, action is Left
21:32:08 T:140667399374784 DEBUG: LIRC: Update - NEW at 76967:000000037ff07be0 00 KEY_DOWN mceusb (KEY_DOWN)
21:32:08 T:140667399374784 DEBUG: OnKey: 167 (0xa7) pressed, action is Down
21:32:12 T:140667399374784 DEBUG: LIRC: Update - NEW at 81154:000000037ff07bdd 00 KEY_OK mceusb (KEY_OK)
21:32:12 T:140667399374784 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
21:32:12 T:140667399374784 DEBUG: Activating window ID: 10617
21:32:12 T:140667399374784 DEBUG: ------ Window Deinit (MyPVRChannels.xml) ------
21:32:12 T:140667399374784 DEBUG: ------ Window Init (MyPVRGuide.xml) ------
21:32:12 T:140667399374784 INFO: Loading skin file: MyPVRGuide.xml, load type: KEEP_IN_MEMORY
21:32:13 T:140667399374784 DEBUG: CGUIEPGGridContainer - SetStartEnd - start=07/22/2015 1:30:00 AM end=08/01/2015 1:30:00 AM
I did not wipe away my .kodi folder before the upgrade. I will try that as a last resort. I have a feeling the epg database is corrupt. I tried clearing the database several times though from the livetv settings and no difference. Channels and recordings are fine. Just guide is broke.
I'm impatient. I blew away userdata. Time to rebuild it and not install half the plugins I don't use anyways this time.
I'm experiencing a similar issue: when calling EPG, Kodi 15 crashes. There were no such issues in Kodi 14, they only began after upgrade to Kodi 15.
Anyone have any ideas how to resolve? I've tried clearing EPG cache, and PVR cache but to no avail.
Part of crash log:
############### Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu Jul 23 18:55:33 BST 2015
Kodi Options:
Arch: x86_64
Kernel: Linux 3.16.0-44-generic #59~14.04.1-Ubuntu SMP Tue Jul 7 15:07:27 UTC 2015
Release: Ubuntu 14.04.2 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/lounge/core (2015-07-23 18:55:33.133867439 +0100)
[New LWP 19420]
[New LWP 19426]
[New LWP 19438]
[New LWP 19441]
[New LWP 19424]
[New LWP 19434]
[New LWP 19423]
[New LWP 19474]
[New LWP 19458]
[New LWP 19447]
[New LWP 19444]
[New LWP 19465]
[New LWP 19475]
[New LWP 19559]
[New LWP 19464]
[New LWP 19489]
[New LWP 19491]
[New LWP 19445]
[New LWP 19561]
[New LWP 19472]
[New LWP 19477]
[New LWP 19492]
[New LWP 19558]
[New LWP 19566]
[New LWP 19468]
[New LWP 19478]
[New LWP 19451]
[New LWP 19567]
[New LWP 19457]
[New LWP 19482]
[New LWP 19568]
[New LWP 19493]
[New LWP 19440]
[New LWP 19480]
[New LWP 19563]
[New LWP 19806]
[New LWP 19467]
[New LWP 19488]
[New LWP 19439]
[New LWP 19481]
[New LWP 19454]
[New LWP 19435]
[New LWP 19564]
[New LWP 19466]
[New LWP 19552]
[New LWP 19565]
[New LWP 19503]
[New LWP 19547]
[New LWP 19506]
[New LWP 19496]
[New LWP 19495]
[New LWP 19494]
[New LWP 19485]
[New LWP 19484]
[New LWP 19479]
[New LWP 19504]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000000000aa8e86 in EPG::CGUIEPGGridContainer::UpdateItems() ()
18:55:25 T:140030574688192 DEBUG: ------ Window Deinit (Settings.xml) ------
18:55:25 T:140030574688192 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
18:55:25 T:140030574688192 DEBUG: ------ Window Init (Home.xml) ------
18:55:25 T:140030574688192 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-x86_64-linux.so)
18:55:25 T:140030574688192 DEBUG: Loading: /usr/lib/kodi/system/ImageLib-x86_64-linux.so
18:55:25 T:140027266852608 DEBUG: AddOnLog: MythTV PVR Client: RunHouseKeeping
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetDriveSpace
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: (CPPMyth)SendCommand: QUERY_FREE_SPACE_SUMMARY
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: (CPPMyth)RcvMessageLength: 23
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetNumChannels
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetTimersAmount
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetRecordingsAmount
18:55:26 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetDeletedRecordingsAmount
18:55:26 T:140030574688192 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0
18:55:26 T:140030574688192 DEBUG: OnKey: left (0xf082) pressed, action is Left
18:55:26 T:140027266852608 DEBUG: AddOnLog: MythTV PVR Client: RunHouseKeeping
18:55:27 T:140030574688192 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0
18:55:27 T:140030574688192 DEBUG: OnKey: left (0xf082) pressed, action is Left
18:55:27 T:140027266852608 DEBUG: AddOnLog: MythTV PVR Client: RunHouseKeeping
18:55:29 T:140030574688192 DEBUG: Previous line repeats 1 times.
18:55:29 T:140030574688192 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0
18:55:29 T:140030574688192 DEBUG: OnKey: left (0xf082) pressed, action is Left
18:55:29 T:140030574688192 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0
18:55:29 T:140030574688192 DEBUG: OnKey: down (0xf081) pressed, action is Down
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetDriveSpace
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: (CPPMyth)SendCommand: QUERY_FREE_SPACE_SUMMARY
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: (CPPMyth)RcvMessageLength: 23
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetNumChannels
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetTimersAmount
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetRecordingsAmount
18:55:29 T:140026226616064 DEBUG: AddOnLog: MythTV PVR Client: GetDeletedRecordingsAmount
18:55:29 T:140030574688192 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0
18:55:29 T:140030574688192 DEBUG: OnKey: right (0xf083) pressed, action is Right
18:55:29 T:140027266852608 DEBUG: AddOnLog: MythTV PVR Client: RunHouseKeeping
18:55:30 T:140030574688192 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
18:55:30 T:140030574688192 DEBUG: OnKey: return (0xf00d) pressed, action is Select
18:55:30 T:140030574688192 DEBUG: Activating window ID: 10617
18:55:30 T:140030574688192 DEBUG: ------ Window Deinit (Home.xml) ------
18:55:30 T:140030574688192 DEBUG: ------ Window Init (MyPVRGuide.xml) ------
18:55:30 T:140030574688192 INFO: Loading skin file: MyPVRGuide.xml, load type: KEEP_IN_MEMORY
18:55:30 T:140030574688192 DEBUG: CGUIEPGGridContainer - SetStartEnd - start=22/07/2015 5:30:00 PM end=26/07/2015 5:30:00 PM
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
I would try to find where the myth plugin stores everything in the .kodi folder and delete it all. You really don't need kodi to store info anyways because it pulls down everything at startup and it only takes a few seconds. There is an option to not store epg in kodis database as well which may work. If all else fails blow up your .kodi folder. Its like starting over with your children and its great.
pvr.mythtv addon doesn't store anything about EPG. Seems this issue is new with last changes included in Kodi 15 before its releasing. Here i never see it for now. I sugger you to open a track with your crash log attached. Also i am interesting you send me the full crash log. Thanks.
EDIT: @andrewj720 your crash log please. I need only the "STACK TRACE" part. No need log part.
Thanks folks. I will later today delete some more files in ~/.kodi to see if it fixes the problem. And I will send STRACE TRACE part of log files to you Janbar, too. Many thanks for replies.
Hi
This is likely not a MythTV related issue, it seems to be Kodi PVR in general as I worked that out with FernetMenta in VNSI sub-forum.
Please join this forum post if it fits your description:
http://forum.kodi.tv/showthread.php?tid=232854
It could be, but here kodi crash with segfault in EPG::CGUIEPGGridContainer::UpdateItems(). That's mean a pointer is invalid or freed during operations. I am waiting a new stack trace to confirm it.
(2015-07-23, 21:17)janbar Wrote: [ -> ]Hi,
STACK TRACE is very long - am unable to PM you or email using forum tools - ok to post it here?
Here you go: Stack Trace part of crash log here: https://drive.google.com/file/d/0By74LYI...sp=sharing
Problem is now resolved but I'm unsure how.
EPG now works fine without crashing Kodi. I didn't change any settings so am unsure what has changed to resolve the problem.
I'm also having this issue, here is my crash log:
23:20:20 T:139978721965824 NOTICE: metahandler: Attempting to retreive meta data for tvshow: Futurama
23:27:48 T:139978738751232 NOTICE: buildLiveTVFileList_Cache
23:28:13 T:139978738751232 NOTICE: Previous line repeats 6 times.
23:28:13 T:139978738751232 ERROR: script.pseudotv.live-ChannelList: Unable to get information about channel 518
23:28:14 T:139978738751232 ERROR: script.pseudotv.live-ChannelList: Unable to get information about channel 521
23:28:15 T:139978738751232 ERROR: script.pseudotv.live-ChannelList: Unable to get information about channel 526
23:28:16 T:139978738751232 ERROR: script.pseudotv.live-ChannelList: Unable to get information about channel 534
23:28:17 T:139978738751232 ERROR: script.pseudotv.live-ChannelList: Unable to get information about channel 544
23:28:18 T:139978738751232 ERROR: script.pseudotv.live-ChannelList: Unable to get information about channel 573
23:28:57 T:139978738751232 NOTICE: buildLiveTVFileList_Cache
23:33:00 T:139982254393536 NOTICE: Previous line repeats 6 times.
23:33:00 T:139982254393536 ERROR: WinSystemX11::RefreshWindow - failed to query xrandr
23:33:01 T:139982254393536 ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:28453270, error_code:5, request_code:18 minor_code:0
23:33:01 T:139982254393536 ERROR: CRenderManager:TonguerepareNextRender - asked to prepare with nothing available
23:33:01 T:139982254393536 NOTICE: Using GL_TEXTURE_2D
23:33:01 T:139982254393536 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
23:33:01 T:139982254393536 NOTICE: GL: NPOT texture support detected
23:33:01 T:139982254393536 NOTICE: GL: Using GL_ARB_pixel_buffer_object
23:42:01 T:139978713573120 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
23:42:01 T:139978747143936 NOTICE: CDVDPlayer::OnExit()
23:42:01 T:139978747143936 NOTICE: DVDPlayer: eof, waiting for queues to empty
23:42:01 T:139978747143936 NOTICE: Closing stream player 1
23:42:01 T:139978747143936 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
23:42:01 T:139978747143936 NOTICE: Waiting for audio thread to exit
23:42:01 T:139978713573120 NOTICE: thread end: CDVDPlayerAudio::OnExit()
23:42:01 T:139978747143936 NOTICE: Closing audio device
23:42:01 T:139978747143936 NOTICE: Deleting audio codec
23:42:01 T:139978747143936 NOTICE: Closing stream player 2
23:42:01 T:139978747143936 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
23:42:01 T:139979022120704 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
23:42:01 T:139978747143936 NOTICE: waiting for video thread to exit
23:42:01 T:139979022120704 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
23:42:01 T:139979022120704 NOTICE: thread end: video_thread
23:42:01 T:139978747143936 NOTICE: deleting video codec
Do you guys use channel icons? If so turn them off and test again.
