2015-07-23, 06:34
I have my local files ported to OPlayer on my iPhone 6. Great for watching whatever, as long as they aren't AC3 encoded, fine. However, a lot of my movies are AC3 and OPlayer can not support them. So, I open Kodi for that - perfect.
One problem, and it has never been addressed; I set up Kodi to browse for my files, only Movies (if I set the "mobile" folder up for movies - MDB scraper) will show on the main screen and TV (if I a folder called "mobile episodes" for TV shows - TVDB scraper). Only one option shows on the main screen (see pic).
I go into Setting-Appearance-Settings and if I have TV episodes loaded, "Movies" is subdued and can NOT be turned on. If I browse for files from the "mobile" folder, only "Movies" shows up and "TV shows" is subdued.
What is the fix for this? I have yet to get an answer... Before updating to Kodi, It worked fine while it was xbmc. Now the code changed somehow and I can not get it to show both "Movies" and TV shows" at the same time.
