Hi!
the Kodi 15.0 is a gr8 release… but i have a problem using it on my iPad Air 2 version 8.4 jailbroken . the problem is when i connect to my HDTV via apple tv, and select screen 2 to go full screen the display is upside down. Does any 1 have similar problem?? Never had this problem running the previous version of Kodi 14.2, so hope its a bug and a fix is coming soon….
You connect it via airplay mirroring or via Lightning - HDMI adapter?
I am connecting via AirPlay Mirroring.
Any Update on this issue...
Wait at least 5 months before asking for an update ... (low prio, real life stuff to do for the next months, only dev which would even work on this).
Ok! Any links on how to downgrade to 14.2. Thanx
The iOS install pages on the wiki tell you how:
iOS (wiki)
Wait a second. A simple workaround is to turn your ios device 180 degrees before starting kodi (or before selecting fullscreen #2). I know this seems to be a ridiculous bug but that whole orientation code was changed in behavior multiple times by apple and is a bit fragil in the kodi codebase.
