Is there any news on when the final Isengard will be made available for raspbian? I am now running RC1 and as far as i know there was no RC2 release and no final release.
Maybe because of vacation time.
You have Kodi 15.1 Isengard debian packages for Raspbian (RPi 1 and 2) here:
http://pipplware.pplware.pt/pipplware/di...in/binary/
They are based on Michael Govern's packages (the ones which are in RPi Foundation repo) with only 2 ou 3 fixes. There is also all PVRs addons updated.
You can download the needed packages and install with dpkg. There are some new dependencies, all are in the repo above.
Or easier, add the following repo to /etc/apt/sources.list:
deb http://pipplware.pplware.pt/pipplware/dists/stable/main/binary /
Save the file, exit to terminal, and add the corresponding key:
wget -O - pipplware.pplware.pt/pipplware/key.asc | sudo apt-key add -
And update and dist-upgrade:
sudo apt-get update
sudo apt-get dist-upgrade
So can I install 15.1 from the raspbian repository in some way? I tried adding the raspbian repository and key manually but it doesn't recognise the update afterwards. If I uninstall kodi and install it again it does so using the old files from the raspberry pi repository mentioned by rascas. This is as far as I get with my limited knowledge
(2015-09-13, 19:23)rascas Wrote: [ -> ]The packages currently available in Raspbian, are fetched from http://archive.raspberrypi.org/debian/pool/main/k/kodi/. This is the RPi Foundation repository.
That ones are the normal Raspbian repository, but it seems they were left out from Raspbian.
That is not correct in my case. My
/etc/apt/sources.list says:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
And looking in the
/pool folder we can find
kodi-15.1. I'm missing something about how apt-get works
Raspbian is mostly a straight recompile of all debian packages with armv6 flags. There are something like 43000 packages in there.
Unless something has changed, the kodi in there is not build for raspberry pi - it is a generic debian kodi that won't work on Pi (it uses deskop GL for example).
The raspberrypi repo is built for raspberry pi, and does contain a kodi 14 that works on pi. Currently there is no kodi 15, but it will come.
You will have to wait until that is ready, or use an external repo that has built kodi 15 for pi (but I haven't tested these, so you'll have to go with advice from people who have).
(2015-09-19, 16:34)datakey Wrote: [ -> ] (2015-09-13, 19:23)rascas Wrote: [ -> ]The packages currently available in Raspbian, are fetched from http://archive.raspberrypi.org/debian/pool/main/k/kodi/. This is the RPi Foundation repository.
That is not correct in my case. My /etc/apt/sources.list says:
And looking in the /pool folder we can find kodi-15.1. I'm missing something about how apt-get works
http://mirrordirector.raspbian.org/ is the same as
http://archive.raspbian.org (kind of, its a mirror).
You should also have /etc/apt/sources.list.d/raspi.list which points to the RPi Foundation repo (
http://archive.raspberrypi.org/)
The rest, popcornmix already explained.
The repo I provided, I compile the packages and test them myself with the help from other ppl too. Its a repo for a small RPi distribuition, Pipplware (currently, website only available in portuguese, sorry):
I am in need of some assistance. I added the source address to my /etc/apt/source.list file but every time I use sudo apt-get update i get an error on Malformed line in source list. /etc/apt/source.list (dist)
Can anyone tell me what I am missing.
And yes I checked the spelling of the site several times over
deb
http://pipplware/pplware.pt/pipplware/di...in/binary/
I get an Error:
W: GPG-Fehler:
http://pipplware.pplware.pt Release: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D9A264BCBAA567BB
How can i fix this?
