Full Version: Getting Kodi Remote for iOS to connect
Hi all,
I'm a newbie to Kodi (40 years as a programmer, though) and can't get the remote on an iPad to find my HTPC.
The PC is running a fresh install of Win7 and Kodi 15.0 (Isengard).
The iPad is running iOS 8.4 and Kodi Remote 1.5.3.
When I try to set up the remote and follow the instructions about how to enable it on the PC, I get the spinning circle on the iPad...
Is there something else to enable on the PC side?
...any reply appreciated...
stp
check the win firewall rules, usually are the guilties. let me know
Thanks for the hint; I tried it out (turned off firewalls in the control panel, rebotted) - it had no effect at all...
Is there more to disabling Windows firewalls than the control panel settings?
stp
mm strange, let's start from beginning... try to connect to http://<kodi_ip>:<kodi_port> from the iDevice safari and let me know if you can access to the web interface. If not, there is a network issue between the iDevice and the kodi appliances.
