Hello
I Have OSMC installed on a Raspberry with Amber skin.
I noticed that the background image (for all films) was not the right resolution :
For example, this is a 1920x1080 picture, and it's look like a 1360x768.
What can i modify to change this ?
Sorry for my bad english, I do my best
With regards!
Seem like it's skin related.
You may try a different view to fit your desire.
I have found the solution
Just edit this file : /usr/share/kodi/system/advancedsettings.xml
and modifiy this line : <fanartres>720</fanartres> to
<fanartres>1080</fanartres>
(2015-08-01, 19:21)Kamiz Wrote: [ -> ]I have found the solution
you can't edit that location, correct way to change the default advancedsettings is to edit (or create)
/storage/.kodi/userdata/advancedsettings.xml
and add (or edit)
<advancedsettings>
</advancedsettings>.
On Openelec yes you can't, on OSMC ?
But anyway my guess is the cached thumbnail remains the same if the thumbnail cache isn't removed, or the source removed and re added.
It's work now !
I have created the file advancedsettings.xml in /storage/.kodi/userdata/ and added the lines.
I have deleted all directory in the thumbnail folder, and delete all table of the database Textures13.db
To make sure, i looked the resolution of some fanart in the Thumbnail and viewed some 1920x1080p pictures (instead of 1280x720 before).
Thanks you guys
