Hi
Cant access any network devices with the new Kodi. Had the same issue before with 64bit versions of Kodi and xbmc. 32 bit seam to work OK, but I can't find a 32 bit version of the new Kodi.
Running a 2009 Mac mini.
Need more info. In what way do you try to access network devices? Also which osx version are you using? We stopped building Kodi for 32bit because the new minimum requirement for Kodi 15 is osx 10.7 which only runs on 64bit macs anyway... Also if you refer to AFP network access - it was dropped completly (even apple stopped support for it in the latest osx versions).
changed to smb(from afp) sharing,and i can now access my synology nas!
smb sharing to my iMac.. broken pipe!! How to get access to my iMac?? iMac is running OS X beta 2 el capitan.
osx 10.10.4
2009 mac mini.
kodi 15.0
Quote:iMac is running OS X beta 2 el capitan
Sigh...
Whats a bet Apple upgraded SMB protocols again in El Capitan to make all file sharing from a Mac broken and incompatible with XBMC/Kodi ?
