Full Version: Asus EeeBox EB1033 (Atom D2550) - £99.99
£99.99
http://www.ebuyer.com/718137-asus-eeebox...1033-b013e
The 1 litre-sized EB1033 offers stable computing capabilities along with quality graphics; and comes with a rotatable VESA mount and abundant connectivity I/O ports. With discrete graphics, it supports full HD 1080P playback and dual display output. The EB1033 is the ideal choice to keep your connected to the world.
Processor - Intel Atom D2550 Dual Core 1.86GHz
Intel NM10 Cipset
Memory - 2GB 1066MHz DDR3 (Expandable to 4GB) 1 x SODIMM slot
Hard Drive - 320GB SATA 5400rpm
Optical Drive - None
Software - Operating System: Microsoft Windows 7 Home Premium 64bit - Free Windows 10 upgrade
Graphics - Nvidia Geforce 610M Graphics
Networking - WLAN 802.11 b/g/n - LAN 10/100/1000 Mbps
Power Supply - 65W
Dimensions - 219 x 172.5 x 29 mm (WxDxH)
Interfaces
2 x USB 3.0
4 x USB 2.0
1 x HDMI
1 x VGA (D-Sub)
1 x External Wi-Fi Antenna
1 x RJ45 LAN
1 x Audio jack
1 x Mic
1 x DC-in
Warranty/Miscellaneous
1 Year Manufacturer Warranty
I understand The Atom D2550 is very inferior to Haswell 2957U but how does the discrete Nvidia Geforce 610M compare to Intel HD graphic?
looking around this seems like end of line product.
would this be as good as HP 260 G1 in terms of graphics performance?
The D2550 is a very weak CPU. Passmark of 664, single threaded of 295.
That compares with a Passmark of 1509, single threaded 815 for the 2957U. The Haswell Celeron is more than twice as fast.
The nVidia graphics will mitigate this a bit, but the Intel GPU does a pretty good job. The advantages over the HP 260 G1 would be the HDMI output, removing the need for a £5 DP->HDMI converter, built in WiFi, and a higher capacity, but slower 320GB 5400rpm HDD vs a much faster 32GB M2 SSD.
