I have rerun my WMC7 setup, I have the latest guide showing/populated in WMC7, but there is no guide showing in Kodi. The channels are correct and showing, but no guide data in Kodi.
My setup was working fine until the last 2 weeks, when MS changed their providers, but WMC& is working fine now....just need to get Kodai 14.2 working.
Any suggestions?
If you have confirmed that wmc now has the guide data, try resetting the kodi epg database.
If that doesn't work, then post the serverwmc log after starting kodi and waiting for kodi to finish downloading guide data. Put the log on pastebin and put a link to it here.
(2015-08-03, 03:19)krustyreturns Wrote: [ -> ]If you have confirmed that wmc now has the guide data, try resetting the kodi epg database.
That worked..thank you! But now my OTA channels won't switch/run/view..the cable channels have no problems viewing.
Your ota channel don't even show up in the channel list? Again, assuming they are fine in media center:
Post the serverwmc log after starting kodi and waiting for kodi to finish downloading guide data. Put the log on pastebin and put a link to it here.
Here is the log...it can't fit in the Pastebin site.
My OTA channels have 2.1, 7.1 etc. the channels with decimals are the only channels that wont stream. They work fine on my WMC7 server, but not on Kodi...this is the first time this has happened.
http://www.megafileupload.com/4Tyt/ServerWMC.log
Click on the FREE User Download that is "grayed out"
Solved...
I must have click on "Kodi"" box under ServerWMC tab - Live TV. Once I unchecked that box, and restarted Kodi and ServerWMC...the live TV from my OTA channels started working.
Again, are you saying the channel, like 7.1 is not showing up in the guide or channel list in kodi? Because according to log it should be, for example:
2015/08/02 15:33:24.901 Received client request: FamilyRoom|192.168.1.13|GetEntries|745287202|1438545714|1439757114
2015/08/02 15:33:25.311 GetEntries> Channel: ABC7 HD-7.1, EPG entries: 339
2015/08/02 15:33:25.311 Finished request GetEntries in 0.41s
this says that serverwmc sent kodi 339 programs entries for channel 7.1. Or are you saying that the channel is not playing?
