Full Version: LibraryAutoUpdate question
Hi all
Im using the lib auto update addon to refresh my library daily. I have defined a cron scheme that works fine for me
However, every time i wake my kodi box from the screen saver mode, after a while it does a lib update. I am guessing this has to do with the option "update after start". However, that option seems to have a delay only, not an "off" switch
Is there still a way for me to have it stop updating after i wake my kodi? The cron setting is enough (and its there for a reason)
Anybody?
It cant be this difficult can it?
If all you want to do is schedule a library update then stop using the add-on and instead schedule a curl command that uses JSON to kick off the scan.
(2015-08-05, 10:17)Milhouse Wrote: [ -> ]If all you want to do is schedule a library update then stop using the add-on and instead schedule a curl command that uses JSON to kick off the scan.
How do I do that?
Still, it leaves my query open to further understand how the add-on works...
