I have installed Server WMC on my Windows 7 laptop. When I'm trying to open it, I get the following message...
RecService > failed to loag EPG
Unrecoverable Error - Server will terminate!
I am using build 1199.
How can I resolve this issue?
I am a newbie, I don't have much experience on these things.
Thank you in advance
Do you have wmc (windows media centre) on your windows 7 pc fully setup and working? ServerWMC is an interface layer between Kodi and WMC so you first need wmc working, then install ServerWMC, then in Kodi enable the pvr addon for pvr.wmc
Check the Kodi wiki for pvr.wmc and ServerWMC setup instructions
(2015-08-05, 00:46)scarecrow420 Wrote: [ -> ]Do you have wmc (windows media centre) on your windows 7 pc fully setup and working? ServerWMC is an interface layer between Kodi and WMC so you first need wmc working, then install ServerWMC, then in Kodi enable the pvr addon for pvr.wmc
Thank you!
I just downloaded Media Center. I will configure it and try again
I will post here if i will have another issue.
Hi again!
I'm trying to configure Media Center but I cannot find
this settings page
Do I need a TV Tuner for Media Center even If I will use it with Kodi?
All I want to do is record series or tv shows from my Kodi.
Thank you in advance.
First, you need a fully functional Windows Media Center PC with access to TV tuner(s) hooked up to OTA or cable TV. Do not do anything else until this is fully configured and you are able to watch TV and record shows.
Then you can install ServerWMC on the same PC.
Then you can connect to ServerWMC via Kodi.
(2015-08-05, 02:54)sbthomas Wrote: [ -> ]First, you need a fully functional Windows Media Center PC with access to TV tuner(s) hooked up to OTA or cable TV. Do not do anything else until this is fully configured and you are able to watch TV and record shows.
Thank you for your answer.
I was thinking that I can record Tv shows only with ServerWMC but it seems like that I need a Tv- Tuner.
Is there any way for recording live Tv shows on Kodi without a Tv-Tuner?
to access liveTV you need to have a tv tuner...
