2015-08-06, 02:33
Hi all,
First of all, let me tell you that I love Rapier. The best feature is probably the NextAired widget on the home screen that automatically tells you which show will air next.
I was trying today to personalise my Rapier a little bit more than it was and activated extra fanart for the first start. After having downloaded them with Artwork Downloader, it worked great in Show View and Episode View. However, it does not seem to work in Season View. When I checked the log file, it looks like the skin isn't trying to fetch any directory or parent directory at all (I can tell from the fact that it won't fail looking in the wrong ones as it does for Show View and Episode View).
As anyone noticed that too? Is it a bug or have I messed up my configuration? I'm sure it wouldn't be too hard of a fix anyway.
Thanks in advance for your help!
