2015-08-09, 20:15
2015-08-10, 07:39
It works for me on iOS 8.4 using Kodi v15 on my iPad. You'll need to get us a debug log (wiki) of when this happens for you.
2015-08-10, 11:59
2015-08-11, 21:41
Log with the included video toolbox, and then disconnected video toolbox
http://xbmclogs.com/pyvzdgj4n
2015-08-12, 10:18
Any chance that this is some interlaced video material you are trying to play? (also please provide a new log with debugging enabled in settings->system->debugging as the link debug log (wiki) told you)
2015-08-21, 13:30
2015-08-21, 14:35
I usually try to not repeat myself lately...
2015-09-08, 17:36
Sorry, that's not writing. Uploaded log work KODI 15.1 for IOS 8.4.
http://xbmclogs.com/plzkglhoz
2015-09-09, 11:06
First you should disable:
Settings → System → Power saving → Try to wake remote servers on access
Its obviously non-working for you.
Try to disable settings->video->sync to display
Try to disable the VU+/Enigma PVR addon (it spams the log so bad man).
Does this fix the playback?
If not - please post a new debug log (wiki) with those settings changed.
2015-09-09, 23:09
Thanks, http://xbmclogs.com/p9jehckab
2015-09-10, 14:27
Are you sure this file plays when VTB acceleration is disabled?
It shows
which indicates black screen indeed
It shows
[h264] no picture
2015-09-10, 20:12
disabled settings, video shows, http://xbmclogs.com/p55q4go8t,
turn on the video toolbox, the video does not show
