I have the following Problem.
If I update the Database and my NAS ist offline, all my Scraped Shows/Movies are erased.
Can I deactivate that somewhere in the Options?
What do you expect that will happen when you update the library while the source is offline?
Do you expect that deletions only happen for missing files and folders on sources that are available/online?
Would you like to be warned that a source is offline and can't be checked?
Yes I would like a warning that all the Shows/Movies from that specific source will be deleted in EMM.
With an abort Button if I don't want that.
Disable Settings -> Movies or TV Shows -> Files and Sources -> Clean Database after updating library
Also don't use Tools -> Clean Database.
There is a warning if you use F5, Edit or Rescraping if the media is offline. But Clean Database is to remote no longer existing media and a warning do not make sense.
