Full Version: Transcoding debunked v4.1.x
Hi gents,
i was trying to build tvheadend 4.1.x with transcoding enabled.
So after hours and days of searching for what i should do before i do it, i've reached this post
https://tvheadend.org/boards/4/topics/13635
but i'm working on ubuntu 15.04 "vivid" also no builds are available yet, so i've used Autobuild.sh -t trusty-amd64, when compiling from source.
everything looking good, and to be honest by building in this way you'll be able to get all the transcoding features in tvheadend web panel.
then i wanted to build it again so,
i've tried installing ffmpeg from this link
http://trac.ffmpeg.org/wiki/CompilationGuide/Ubuntu
and everything went fine
but when i try to build using these options
AUTOBUILD_CONFIGURE_EXTRA=--enable-libffmpeg_static,libiconv,ccache,bundle,dvbcsa,kqueue,tsdebug,gtimer_check ./Autobuild.sh -t trusty-amd64
i get these options as failed
Checking support/features
checking for ffmpeg libraries ... fail
Options
libffmpeg_static no
libffmpeg_static_x264 yes
inotify yes
epoll yes
uriparser yes
ccache no
tvhcsa yes
bundle no
dvbcsa no
dvben50221 no
kqueue no
dbus_1 yes
android no
tsdebug no
gtimer_check no
can someone please illustrate why??
i want libffmpeg_static to be on, also the other options "which i really don't know what they are doing"
please can someone illustrate why the static ffmpeg isn't working? and what are all these options.
Thanks very much and best regards
Anyone?? somebody??
