Full Version: tv shows doesnt clean
i sometimes throw folders that i organize later into the directory as long as the season is complete or i just delete some shows after i do updates to the directories. the problem im having is that the shows are ghosting in the ember list. no matter what i do. i have tried "remove from database" and "delete tv show" and i also do what i do for movies and reload the data by right clicking the name and it pops up saying its no longer available and remove it. all methods do remove them from the list but if i close the program and start it up everything is back.
(2015-08-18, 20:54)dr-oopie Wrote: [ -> ]i sometimes throw folders that i organize later into the directory as long as the season is complete or i just delete some shows after i do updates to the directories. the problem im having is that the shows are ghosting in the ember list. no matter what i do. i have tried "remove from database" and "delete tv show" and i also do what i do for movies and reload the data by right clicking the name and it pops up saying its no longer available and remove it. all methods do remove them from the list but if i close the program and start it up everything is back.
Sounds like a bug and the database changes are not commited after SQL command. Please check if you have a file called "MyVideosXX.emm-journal" in .\Ember Media Manager\Settings folder.
If a journal file is still existing after removing a tv show or closing Ember, the SQL command was aborted before he was finished. In this case please upload your log file .\Ember Media Manager\Logs to pastebins.com and i will try to find the bug. Thx.
(2015-08-18, 21:24)DanCooper Wrote: [ -> ]
ok i tried it and i did see a journal file but once i closed it, the journal file disapeared but when i relaunched the program, the listings are still there like nothing happened. ill post a log if you still require it.
edit: i deleted the old log as i was scraping a bunch of files so i cleared the log, started the program, and deleted 3 ghost listings. close the program and opened the log.
time,logger,callsite,threadid,level,message,exception
2015-08-18 16:14:48.0091,Ember_Media_Manager.My.MyApplication,Ember_Media_Manager.My.MyApplication.MyApplication_Startup,1,INFO,====Ember Media Manager starting up====,
2015-08-18 16:14:49.4932,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.frmMain_Load,1,INFO,frmMain_Load,
2015-08-18 16:14:49.5432,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_MovieSet,6,TRACE,loadMovieSetScrapersModules started,
2015-08-18 16:14:49.5432,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadGenericModules,8,TRACE,loadModules started,
2015-08-18 16:14:49.5432,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_TV,5,TRACE,loadTVScrapersModules started,
2015-08-18 16:14:49.5432,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,loadMovieScrapersModules started,
2015-08-18 16:14:49.5432,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.LoadWithGUI,1,TRACE,LoadWithGUI(),
2015-08-18 16:14:49.9332,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Data.IMDB.ScraperModule.IMDB_Data_Movie,
2015-08-18 16:14:49.9332,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Data.MoviepilotDE.ScraperModule.MoviepilotDE_Data_Movie,
2015-08-18 16:14:49.9332,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_MovieSet,6,TRACE,Scraper Added: scraper.Data.TMDB.ScraperModule.TMDB_Data_MovieSet,
2015-08-18 16:14:49.9532,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_TV,5,TRACE,Scraper Added: scraper.Image.FanartTV.ScraperModule.FanartTV_Image_TV,
2015-08-18 16:14:49.9532,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Data.OFDB.ScraperModule.OFDB_Data_Movie,
2015-08-18 16:14:49.9532,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_MovieSet,6,TRACE,Scraper Added: scraper.Image.FanartTV.ScraperModule.FanartTV_Image_MovieSet,
2015-08-18 16:14:49.9802,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_TV,5,TRACE,Scraper Added: scraper.Image.TMDB.ScraperModule.TMDB_Image_TV,
2015-08-18 16:14:49.9802,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_MovieSet,6,TRACE,Scraper Added: scraper.Image.TMDB.ScraperModule.TMDB_Image_MovieSet,
2015-08-18 16:14:49.9802,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Data.TMDB.ScraperModule.TMDB_Data_Movie,
2015-08-18 16:14:49.9802,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Image.FanartTV.ScraperModule.FanartTV_Image_Movie,
2015-08-18 16:14:49.9802,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Image.TMDB.ScraperModule.TMDB_Image_Movie,
2015-08-18 16:14:49.9972,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_TV,5,TRACE,Scraper Added: scraper.Image.TVDB.ScraperModule.TVDB_Image_TV,
2015-08-18 16:14:49.9972,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Theme.GoEar.ScraperModule.GoEar_Theme_Movie,
2015-08-18 16:14:49.9972,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Theme.TelevisionTunes.ScraperModule.TelevisionTunes_Theme_Movie,
2015-08-18 16:14:50.0162,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Trailer.Apple.ScraperModule.Apple_Trailer_Movie,
2015-08-18 16:14:50.0162,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Trailer.Davestrailerpage.ScraperModule.Davestrailerpage_Trailer_Movie,
2015-08-18 16:14:50.0292,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Trailer.HDTrailersNET.ScraperModule.HDTrailersNet_Trailer_Movie,
2015-08-18 16:14:50.0292,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Trailer.IMDB.ScraperModule.IMDB_Trailer_Movie,
2015-08-18 16:14:50.0432,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,Scraper Added: scraper.Trailer.TMDB.ScraperModule.TMDB_Trailer_Movie,
2015-08-18 16:14:50.0773,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_TV,5,TRACE,loadTVScrapersModules finished,
2015-08-18 16:14:50.0773,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_MovieSet,6,TRACE,loadMovieScrapersModules finished,
2015-08-18 16:14:50.0773,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadScrapersModules_Movie,36,TRACE,loadMovieScrapersModules finished,
2015-08-18 16:14:51.1133,EmberAPI.ModulesManager,EmberAPI.ModulesManager.loadGenericModules,8,TRACE,loadModules finished,
2015-08-18 16:15:13.5225,EmberAPI.Database,EmberAPI.Database.CloseDatabase,1,ERROR,CloseDatabase    There was a problem closing the media database.,"EXCEPTION OCCURRED:System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database
cannot VACUUM from within a transaction
   at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
   at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
   at System.Data.SQLite.SQLiteDataReader.NextResult()
   at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
   at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
   at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
   at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
   at EmberAPI.Database.CloseDatabase(SQLiteConnection& connection)*   at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
   at EmberAPI.Database.CloseDatabase(SQLiteConnection& connection)"
2015-08-18 16:15:13.9785,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.frmMain_FormClosed,1,INFO,====Ember Media Manager exiting====,
(2015-08-18, 23:13)dr-oopie Wrote: [ -> ]
Yes please post the log file.
If the journal file still existing after removing tv show and only removed after/while closing Ember? This file should be only existing a short time until the SQL commit is complete.
(2015-08-18, 23:22)DanCooper Wrote: [ -> ]
(2015-08-18, 21:24)DanCooper Wrote: [ -> ]Sounds like a bug and the database changes are not commited after SQL command. Please check if you have a file called "MyVideosXX.emm-journal" in .\Ember Media Manager\Settings folder.
i posted the short log in the OP.
yes it appears that the journal file is still there after i remove the ghost listings even if i let the program idle for 30min. if i scrape new shows i did notice that they are listed except they are just reading the folder name and not giving me the checkmarks. if i refresh the new shows that are scraped already all the green checkmarks show up.
Thx, i will check that tomorrow.
(2015-08-19, 01:35)DanCooper Wrote: [ -> ]Thx, i will check that tomorrow.
thank you! just an update, i added another season and also notice that while it is detecting the video files and scraping the video files like images and nfo, the program has the red text in the title of the episode with the no images as if the video file is missing but its not, i reload it and open file location within the program
as an update to my issue, i manage to remove all the tv shows that displayed after removing and restarting the program by doing a "database clean" but 1 of the problems still continues. new tv shows are getting scraped and are being indexed in ember but its still showing them as red and no images are loading. everything is greyscale. the im able to scrape and open the file location from ember but i dont know why its showing them red as if they are missing.
