I accidentally changed by skin on kodi to the conq skin and I have no way to navigate through it on my iPad. Is there a way I could fix this. It's driving me crazy.
Not 100% on iOS but if you download a file manager app from the app store and then navigate to where Kodi is installed
(/private/var/mobile/Library/Preferences/Kodi/userdata/)
and then the addons folder find the folder for the new skin and delete it.
Then when Kodi boots next time it will load the default skin.
ssh into the ipad and do:
rm /var/mobile/Library/Preferences/Kodi/userdata/guisettings.xml
This will reset all settings to default (including the selected skin).
Just use iFile from Cydia to delete the file ;)
It gives me an error when I want to install IFile
Sorry Ned Scott what's ssh I'm new at this
If iFile doesn't work then install "iOS Terminal" from Cydia and enter the command Memphiz gave you.
"Solved"..
you are the best thank you to all for your help
