I have this device Eweat EW802, it comes with installed kodi 13.1 It works fine, but if I try anything higher, no video works, just jumping screenshots and loud hissing noise. What am I doing wrong?
Can you get us a
debug log (wiki) of when you play a video using Kodi v15.1?
Try disabling amcodec under Kodi -> Settings -> Videos -> Acceleration
Tried disabling them one by one. Same problem. Sound does not work correctly.[/align]
As I understand, video is working fine, the sound is the issue here.
Go into Settings -> System -> Audio output, and disable any of the passthrough options. See if that makes any change.
