2015-08-23, 16:38
This is really a minor issue and may have already been reported, although I didn't see it. Every time I exit Kodi from the "s" menu or use Shutdown from the Home Menu I get a report from Finder that Kodi quit unexpectedly. This doesn't happen if I go into windowed mode and select Quit from the Kodi pulldown menu. As I said, it's a minor issue since it doesn't seem to be causing any problems. Perhaps it's just a quirk with MacOSX that can't be resolved.
Problem Details and System Configuration
Edit: I should add that I'm seeing the same issue on 2 different systems.
