Full Version: MythTV plugin issues
I seem to be having issues with the latest release of the mythtv backend - the error message i'm getting is "MainServer: MainServer::HandleVersion - Client speaks protocol version 77 but we speak 87!" - I'm guessing they updated the API and this hasn't been propagated through to the mythtv client
If this is/is not the case, could I please get some help resolving this issue?
The Mythtv pvr addon has been updated to support Protocol 87, see
http://janbar.github.io/pvr.mythtv/download/index.html
Depending on your mythtv configuration, you may still have problems if you are using DVB-S/S2 (satellite) see
https://code.mythtv.org/trac/ticket/12495
Mike
I just upgraded to the latest plugin release as per that post, and get the following message:
MainServer: MainServer::HandleVersion - Client sent incorrect protocol token for protocol version. Refusing connection!
Any suggestions?
You need to provide a full kodi debug log
Also please confirm the mythtv backend version
It should be MythTV Version : v0.28-pre-3054-g2bedfc5 as a minimum
If it is not please update (there was a bug a few days ago in mythtv concerning protocol token)
Edit:
There was another update this morning (UK time) for Ubuntu (nothing to do with protocol token)
MythTV Version : v0.28-pre-3055-gd231e46
Mike
