I get no gui sounds on startup and after about 10- 20 mins of being on the bottom slid bar starts to over lap the test like LIVE TV and VIDEOS start to over lap each other i am running this on Android box with kodi 15.1.1 and the box is a RK 3288 on android version 4.4.2 is have been happening since the update to the last version i have already loaded the REP for the Rapier skin also and no luck can some one help
I think i found the problem its in your Rapier sound / SOUNDS.XML file I replaced it with one from the old version of the skin start up sound is working again ... so you should fix it when you have a chance ....
but still looking for the over laping problem could use a hand with that ?
Hi peterbl.
Sorry, but I removed the startup sound and it will remain this way.
I was annoyed by it and a lot of other people have complained about it.
You can edit the sounds.xml file yourself to still use the startup sound - as I kept the code in.
Delete line 71
<activate>-</activate>
replace line 72
<!--<activate>startup.wav</activate>-->
with this:
Or as you suggest, you can use a previous version.'
I'm not quite understanding your other issue. Can you please explain in detail? Maybe with some screenshots
Cheers
Gade
ok i will take some picture of the problem for you thanks i like the startup sound you know it working hahaha
