Full Version: Timeshift solution with VDR and VNSI
Hi all,
My setup uses VDR with the VNSI plugin as the backend and KODI with the VNSI client plugin as the frontend. The plan is to setup timeshift. However I am not 100% sure about the solution / setup.
Should I setup the timeshift functionality only at the frontend (e.g. KODI client) and how does that work if I want to lets say save a running program on the backend? Or should I setup timeshift at the backend (VDR server)? But in the later case I am note sure how the VNSI plugin would support it?
Any thought / Ideas?
Thanks a lot for your feedback / Nick
Timeshift buffers are created on the backend. THe timeshift settings available in "client specific" are for convenience and do the same as the settings on the backend.
