___________________________________
Unity the creation of
Eddage, I have taken on the task of completing the skin where he left off. For more information you can see his original thread
here.
watch gallery
The skinshortcuts addon is used to implement the main and sub menus on the home screen.
Unity is compatible with Helix and Isengard at this point, and should be installed using the repo link below.
Bumpaneer's Repo v1.0.2 -
Download Link
I am still working through the last remaining skin script files. These should hopefully be completed soon.
Incomplete Files
script-NextAired-TVGuide.xml
Awesome! So glad you took this on. I always loved this skin. Have been dying to see it progress. Thank you!
Thanks for the Isengard updates. This has been my skin of choice for a while.
Awesome skin. Thanks for your hardwork. I am enjoying it.
Is there a way to make the submenu appear once the parent menu is selected instead of clicking on the down arrow on the remote controller or keyboard?
Thanks again?
This skin is awesome, it should replace "confluence" in the next versions of kodi. I would like to see the android lollipop wallpaper replaced, the skin needs something more original.
(2015-09-20, 07:39)dibson Wrote: [ -> ]Awesome skin. Thanks for your hardwork. I am enjoying it.
Thanks again?
I am still trying to figure out a way that looks good to be able to accomplish this. The problem is the dynamic size of the sub menu once skin.shortcuts started being used to allow customization of the main and sub menus. I'll be sure to update this thread if anything gets figured out.
Beutiful skin but...erm...I can't find the File Manager
Where is it hiding?
By default it is a submenu of System (once on System, hit down to bring up the submenu). If you have customized your main menu with skinshortcuts, its wherever you put it.
I had leftover settings from a previous Unity installation and they messed up my menus.
A skin reset fixed it.
Thanks for your help.
This is the best skin ever!
do you still work on this?
Yes, I am slowly finishing up the last couple of files.
While you are working on those last files, could you take a look at the following?
- When searching for subtitles, the info bar and the time\end time stay on screen and hide part of the list of subtitles and a large part of the filename
- The first and last home menu entries should be centered when selected. Now it is difficult to see if the last or the next-to-last item is selected.
- The info bar displays the info label instead of the info text. This happens when there is no tagline in the info screen (the genre of the film is displayed instead).
Now that I think of it, the problem might be in the info screen code. Is it supposed to show the tagline below the film title?
That's all and thanks for the skin
