Here is the log...
2015/09/22 13:59:30.116 OpenLiveStream> -----------------start------------------------
2015/09/22 13:59:30.118 OpenLiveStream> client: emby-PC requesting live stream on channel WFLDDT/3
2015/09/22 13:59:30.119 LiveRemuxStream> live-tv started
2015/09/22 13:59:30.120 SetChannel> Channel: 3 : WFLDDT - 2D83EB = { (202 : WFLDDT - 634F) + [ 78.202 : wfld fox-3 - 2D83E5] }
2015/09/22 13:59:30.120 SetChannel> Tuners available for this channel: 5
2015/09/22 13:59:30.120 SetChannel> Tuner DecoyMethod: OnDemand
2015/09/22 13:59:30.120 SetChannel> ---
2015/09/22 13:59:30.121 SetChannel> Attempt: 0, Tuner: Silicondust HDHomeRun Tuner 10207D19-0 / 7c6d5ca9-ec0e-4e02-9e4c-3319d9d986ab
2015/09/22 13:59:30.121 SetChannel> > Encrypted: False
2015/09/22 13:59:30.122 SetChannel> > RecorderInfo found: True
2015/09/22 13:59:30.123 SetChannel> > Recorder Content Protection: PROT_COPY_FREE
2015/09/22 13:59:30.154 SetChannel> > Status: Available, client:
2015/09/22 13:59:30.154 SetChannel> *** requested number of available tuners found, stopping search ***
2015/09/22 13:59:30.154 SetChannel> ---
2015/09/22 13:59:30.154 SetChannel> available tuners found: 1 [decoys:0], requested: 1, searched: 1
2015/09/22 13:59:30.154 SetChannel> Tuner: Silicondust HDHomeRun Tuner 10207D19-0 will be used for the live stream
2015/09/22 13:59:30.156 SetChannel> Recorder acquired: True
2015/09/22 13:59:30.157 SetChannel> TuneRequest set
2015/09/22 13:59:30.363 LiveRemuxStream> wtv recording started in 0.24 sec
2015/09/22 13:59:30.363 LiveRemuxStream> stream output file: LiveTV_emby-PC_ClearQAM_3_2015_09_22_13_59_30.ts
2015/09/22 13:59:30.364 LiveRemuxStream> started remux thread: 'WFLDDT-3:2982891'
2015/09/22 13:59:30.385 Remux::FindDescriptors> Scanning wtv for streams...
2015/09/22 13:59:32.005 Parse> Guid: 0 took 1.62 sec, it was attempted 791 times
2015/09/22 13:59:32.005 Parse> Next 4 Guids: 0.00 sec, 0.00 sec, 0.00 sec, 0.00 sec,
2015/09/22 13:59:32.006 Parse> Language 'eng' for stream Id 17
2015/09/22 13:59:32.006 Parse> Language 'spa' for stream Id 18
2015/09/22 13:59:32.294 Parse> Total Descriptor parse time: 1.91 sec
2015/09/22 13:59:32.294 Pass Type: 'Descriptor':
2015/09/22 13:59:32.294 > WtvToPesDemuxer:
arse> total guid headers processed: 500 (Min:500 - Max:2,000)
arse> total data packets processed: 102
2015/09/22 13:59:32.298 Remux::FindDescriptors> wtv scanned (1.91 sec), Streams found:
2015/09/22 13:59:32.298 > Audio: ID:17 (eng) ac3 2.0 48000 Hz 448 kb/s
2015/09/22 13:59:32.298 > Audio: ID:18 (spa) ac3 2.0 48000 Hz 192 kb/s
2015/09/22 13:59:32.298 > Video: ID:19 mpeg2video MP-HL 1280x720p fps: 60000/1001 AR: 16:9
2015/09/22 13:59:32.298 > SubTitle: ID:20 ClosedCaption
2015/09/22 13:59:32.298 Remux::FindDescriptors> Output streams:
2015/09/22 13:59:32.370 LiveRemuxStream> 'ts' file created, size: 491,520 in 2.01 sec
2015/09/22 13:59:32.370 LiveRemuxStream> total time: 2.25 sec
2015/09/22 13:59:32.386 OpenLiveStream> stream path returned to client: smb://rashnetwork/administrator:********@WIN7-SERVER-PC/Recorded TV/TempSWMC/LiveTV_emby-PC_ClearQAM_3_2015_09_22_13_59_30.ts
2015/09/22 13:59:32.386 OpenLiveStream> -----------------done-------------------------
2015/09/22 13:59:32.387 Finished request OpenLiveStream in 2.27s
2015/09/22 13:59:34.650 Received client request: emby-PC|192.168.1.199|StreamStartError|smb://rashnetwork/administrator:********@WIN7-SERVER-PC/Recorded TV/TempSWMC/LiveTV_emby-PC_ClearQAM_3_2015_09_22_13_59_30.ts
2015/09/22 13:59:34.650 StreamStartError> client 'emby-PC' reports error opening stream, will close stream down
2015/09/22 13:59:34.650 StreamStartError> client 'emby-PC' path to stream file: 'smb://rashnetwork/administrator:********@WIN7-SERVER-PC/Recorded TV/TempSWMC/LiveTV_emby-PC_ClearQAM_3_2015_09_22_13_59_30.ts'
2015/09/22 13:59:34.650 StreamStartError> client 'emby-PC' calling CloseStream
2015/09/22 13:59:34.650 Remux::Stop> stop remux requested
2015/09/22 13:59:34.683 Pass Type: 'Remux':
2015/09/22 13:59:34.683 > WtvToPesDemuxer:
arse> total guid headers processed: 2,610
arse> total data packets processed: 452
2015/09/22 13:59:34.695 Remux> ENDED, >>>>>>>>>> Run Time: 0.04 min <<<<<<<<<<
2015/09/22 13:59:34.710 LiveRemuxStream::Close> remux stopped successfully
2015/09/22 13:59:34.760 DeleteTS> ts file size: 5,046,272
2015/09/22 13:59:34.761 LiveRemuxStream::Close> ts file deleted: C:\Users\Public\Recorded TV\TempSWMC\LiveTV_emby-PC_ClearQAM_3_2015_09_22_13_59_30.ts
2015/09/22 13:59:34.761 RecordToWTV::Close> isPassive is False => COM recorder will be stopped
2015/09/22 13:59:35.373 LiveRemuxStream::Close> wtv closed successfully
2015/09/22 13:59:35.423 LiveRemuxStream::Close> wtv file size: 5,767,168 (0x580000)
2015/09/22 13:59:35.423 LiveRemuxStream::Close> wtv file deleted: C:\Users\Public\Recorded TV\TempSWMC\LiveTV_emby-PC_ClearQAM_3_2015_09_22_13_59_30.wtv
2015/09/22 13:59:35.423 LiveRemuxStream::Close> closed in 0.77 sec
2015/09/22 13:59:35.423 Close> closed stream for client: emby-PC
2015/09/22 13:59:35.423 Finished request StreamStartError in 0.77s
