Full Version: Unable to add favourites to TV submenu
Running Kodi 15.1 and Transparency 8.0.8. on Windows 8.1
As the title says, I can't add any favourites to the TV submenu.
I enable the submenu, and scroll down to the item 'Favourite 1' and select it. The radio button lights up, but the flyout box labelled 'Select favourite:' just does not appear.
The process works fine when adding favourites to a custom submenu.
I have two PCs running the same version, and the behaviour is the same.
I was definitely able to do this in the past, although it may have been several versions ago.
Any idea what's going wrong?
thx for the report!
it will be fixed in the next release.
in case you're that way inclined, replace the SkinSettings.xml file in the 720p directory with this one:
SkinSettings.xml
All working now, thanks for fixing it so quickly!
