Full Version: Question for anyone using MQ6 on isengard with trakt
Hi
I have this great skin installed on my Pi2.
I had been using Ace skin for a few months beforehand and when as I have trust setup after I watch something it popped up at the end asking me to rate it but for some reason i don't get the pop up on MQ6.
Just wondering if anyone uses trakt and do you get the pop ups it's not really a problem just wondering why
Cheers
+1 My workaround on Windows 10 is to restart kodi. I noticed it one night after binge watching movies. It worked on the first movie, then after that it stopped. It seems random as to when it will stop asking to rate, but it's usually after 2-3 movies for me anyways. Hopefully that helps for a temp fix Smile
