Full Version: CEC setting "When the TV is switched off" is not working
Hi
I've enabled CEC support on my Raspberry Pi 2. Everything works great except that my Pi shuts down when I power off the TV/Reveiver. I did some Google searches and most folks say that I should set the "When the TV is switched off" option to "Ignore". I've already done this but it's not working. Does anyone have any suggestions?
I'm running OSMC August 2015 2015.08-1 running Kodi 15.1
Your Pi shouldn't be shutting down when you power off your TV. Be sure that you're not powering your Pi off the TV.
I'd check your logs to see what's going on.
Sam
Thanks Sam. I was a little intimidated at the thought of looking through log files since I'm somewhat new to Linux and really new to Raspberry Pi/Kodi. After a few minutes on Google, was able to locate my log file and determine that tv power off was not the issue. I have an Onkyo receiver and had been pressing the "All Off" button to power off the receiver and tv. This was getting the pi too.
So, I added a keymap file and set the All Off command to just reboot the pi.
All is working now. Thanks.
