Is there a add-on that are able to display filename together with the picture, we use the filename to indicate where the picture are taken
/Kurt
You can try messing with different displays. If they are in folders, you can see the folders. If you enable info on each picture via context menu, you can see each picture info. If you set the skin to info view, the same.
