2015-11-30, 13:38
I've seen a game.moonlight addon on github but it's not included in openelec garbear builds...
What's the current state of game.moonlight?
(2015-11-30, 13:38)evilsephiroth Wrote: [ -> ]I've seen a game.moonlight addon on github but it's not included in openelec garbear builds...No idea but see http://forum.kodi.tv/showthread.php?tid=220965
(2015-12-01, 17:56)garbear Wrote: [ -> ](2015-11-30, 13:20)evilsephiroth Wrote: [ -> ]I was wondering about the current state of nvidia gamestream inclusion in these builds...
I saw the addon in the garbar repo (game.moonlight)...
If there are instructions to build myself and include in a regular kodi-retroplayer installation, would be fine
game.moonlight was the result from one of our Google Summer of Code students this summer. It is a proof-of-concept and needs changes to its build system, as well as changes in RetroPlayer core. This will be one of my primary focuses when I'm done with the controller util. Check back around then when I've picked up development again.
(2016-01-25, 21:01)garbear Wrote: [ -> ]Well there's your answer The controller configuration utility is nearing completion, so i'll be working on this again sometime in feb or marchDo you know if the "server" machine (running Windows in my case) needs to be left unlocked as with Steam In-Home Streaming? Steam needs the monitor to be on and the machine to be unlocked... quite a let down IMHO.
(2016-01-26, 22:52)ashlar Wrote: [ -> ]I believe that is the case as well. If the monitor is not on I don't know how GameStream (or Steam) could find a screen to render the game to. These streaming systems literally just open the game on your computer as per normal and stream your screen (ie. desktop record but in nice ways).(2016-01-25, 21:01)garbear Wrote: [ -> ]Well there's your answer The controller configuration utility is nearing completion, so i'll be working on this again sometime in feb or marchDo you know if the "server" machine (running Windows in my case) needs to be left unlocked as with Steam In-Home Streaming? Steam needs the monitor to be on and the machine to be unlocked... quite a let down IMHO.
(2016-02-01, 23:57)Scourge Wrote: [ -> ]Closest solution I'd know for that is this: http://www.amazon.com/CompuLab-fit-Headl...B00FLZXGJ6This is what I had in mind when I mentioned workarounds. On the other hand, the requirement for the machine being unlocked is... I find it crazy. But I don't know the technicalities involved, I'm speaking just as an end-user.
(2016-01-26, 22:52)ashlar Wrote: [ -> ](2016-01-25, 21:01)garbear Wrote: [ -> ]Well there's your answer The controller configuration utility is nearing completion, so i'll be working on this again sometime in feb or marchDo you know if the "server" machine (running Windows in my case) needs to be left unlocked as with Steam In-Home Streaming? Steam needs the monitor to be on and the machine to be unlocked... quite a let down IMHO.
