Hi, I am trying to customize my Black Glass Nova skin, but I am having trouble accessing images for background and button (thumbnail?) art. When I try to select image, then single image I only have access to a single folder. I don't know where this folder is, so I have not been able to insert my images into it. Same for thumbnails. Is there some way I can access all folders on my PC? The only options I have are the preselected folder (called SuperRepo) and Cancel. The OK and the New Folder (and mirror image) options are greyed out.
Christopher
Thanks for your reply Tgx. Unfortunately I cannot find File Manager in the Settings menu. Which submenu is it under? I have:
- Appearance
- Videos
- Music
- Pictures
- Live TV
- Add-ons
- Services
- System
- Weather
- Go Live black Glass
- Skin settings
I think I have been trhough them all, but have not found file manager? Am I looking in the wrong place?
It's in the submenu of the settings item in the home screen, if you have not removed it with the home menu editor.
Tgx
Ooops,
yes removed that to avoid the kids messing stuff up. Thought everything would be available using the 'S' button, but guess not. Anyway to get the original Home Menu settings back?
Never mind, think I found it...
I actually think this is a big limitation of Kodi. I've often wanted to remove these menus from the home screen for cleanliness, but can't do it because it's then anything to ever add anything!
