Full Version: Share your themes : Viewtypes and color schemes
RESERVED for sharing your settings
Post here your viewtypes and color schemes screenshots.
Share your work providing zip files Smile
Sharing viewtypes :
Please use the export function in templates for single viewtype :
https://github.com/Jayz2K/skin.KOver#wor...-templates
Give your zip file the number of the template it's exported from. This way users will know where it will be imported to.
Please use the export function in skin settings for multiple viewtypes :
https://github.com/Jayz2K/skin.KOver#export-viewtypes
Give your zip file the section it's exported from or "ALL" if a complete export. This way users will know it will overrides the corresponding section.
Sharing color schemes :
Please use the export function in skin settings for colors export :
https://github.com/Jayz2K/skin.KOver#exp...lor-scheme
Importing users viewtypes and color schemes :
Please use the import function in skin settings (works for both) :
https://github.com/Jayz2K/skin.KOver/blo....md#import
Information
Note that the export / backup feature doesn't save pictures for user custom backgrounds. There is no feature availble in KODI to do that. If you want to share viewtypes with Blocs custom backgrounds, provide pictures in a separated zip file. Final user will have to remap them manually with the designer. Please give explaination for which picture goes where Wink
My view Poster Degrated 1 and Poster Degrated 2
https://www.dropbox.com/sh/vwii6046yb783...lSPsa?dl=0 (copy the images to a folder outside of the skin files)
Picture vignettefullscreenblack.png => Use the Background block, choose picture
picture Fond Black background.png =>Use for Block 1 - 2 and Block 4 with Background image .
