Full Version: Share your themes : Custom lists
Pages: 1 2 3 4 5 6 7 8 9 10 11 12
RESERVED for sharing your settings
Post here your custom lists.
Share your work providing screenshots and xml files.
PLEASE USE THE CODE TAG FOR COPY / PASTE OR SHARE A LINK TO THE FILE
Sharing custom lists :
Informations about custom lists :
https://github.com/Jayz2K/skin.KOver#exp...stom-lists
WARNING !!!
Custom lists are skin files, meaning each KOver update will override them.
Always keep a safe copy of your / or downloaded code.
You will have to replace them after an update
BOOKMARK VIEW
This is intended to be used with a 3x3 layout, horizontal scroll
Itemlayout :
        <itemlayout width="382" height="1067">
            <control type="group">
                <top>120</top>
                <control type="image">
                    <left>0</left>
                    <top>0</top>
                    <width>381</width>
                    <height>960</height>
                    <aspectratio>scale</aspectratio>
                    <texture colordiffuse="$INFO[Skin.String(Color.B1ItemNF)]">common/white.png</texture>
                </control>
                    <left>0</left>
                    <top>0</top>
                    <width>381</width>
                    <height>380</height>
                    <texture colordiffuse="FFFFFFFF">$VAR[ThumbLandscape]</texture>
                </control>
                <control type="label">
                    <top>400</top>
                    <left>49</left>
                    <width>284</width>
                    <height>80</height>
                    <align>left</align>
                    <font>Font36</font>
                    <textcolor>$INFO[Skin.String(Color.B1Txt1NF)]</textcolor>
                    <label>$INFO[ListItem.Label]</label>
                </control>
                <control type="textbox">
                    <top>510</top>
                    <left>49</left>
                    <width>284</width>
                    <height>334</height>
                    <font>FontSmall</font>
                    <textcolor>$INFO[Skin.String(Color.B1Txt2NF)]</textcolor>
                    <label>$INFO[ListItem.Plot]</label>
                </control>
                    <bottom>40</bottom>
                    <left>49</left>
                    <width>328</width>
                    <height>24</height>
                    <align>left</align>
                    <font>FontSmallR</font>
                    <label>$INFO[ListItem.Duration,, mins]</label>
                </control>
                    <description>Rating value</description>
                    <right>49</right>
                    <bottom>26</bottom>
                    <width>100</width>
                    <height>50</height>
                    <aspectratio align="left">keep</aspectratio>
                    <texture colordiffuse="$VAR[CategoryColor]" fallback="rating0.png">$INFO[ListItem.StarRating,]</texture>
                    <visible>IsEmpty(ListItem.Property(ChannelName)) + IsEmpty(ListItem.ChannelName)</visible>
                </control>
            </control>
        </itemlayout>
Focusedlayout :
        <focusedlayout width="382" height="1067">
                <left>0</left>
                <top>0</top>
                <width>381</width>
                <height>120</height>
                <texture colordiffuse="$VAR[CategoryColor]">common/white.png</texture>
            </control>
                <left>24</left>
                <top>20</top>
                <width>200</width>
                <height>80</height>
                <aspectratio>keep</aspectratio>
                <texture colordiffuse="$INFO[Skin.String(Color.B1Txt1F)]">material/left.png</texture>
            </control>
                <right>24</right>
                <top>20</top>
                <width>200</width>
                <height>80</height>
                <texture colordiffuse="$INFO[Skin.String(Color.B1Txt1F)]">material/right.png</texture>
            </control>
                <top>120</top>
                    <left>0</left>
                    <top>0</top>
                    <width>381</width>
                </control>
                    <left>0</left>
                    <top>0</top>
                    <width>381</width>
                </control>
                    <left>0</left>
                    <top>-85</top>
                    <width>381</width>
                    <height>200</height>
                    <texture colordiffuse="$VAR[CategoryColor]">osd/channeldown.png</texture>
                </control>
                    <top>400</top>
                    <left>49</left>
                    <width>284</width>
                    <height>80</height>
                    <align>left</align>
                    <font>Font36</font>
                </control>
                    <top>510</top>
                    <left>49</left>
                    <width>284</width>
                </control>
                    <bottom>40</bottom>
                    <left>49</left>
                    <width>328</width>
                    <height>24</height>
                    <align>left</align>
                </control>
                    <right>49</right>
                    <bottom>26</bottom>
                    <width>100</width>
                    <height>50</height>
                </control>
            </control>
        </focusedlayout>
Link to the Template file (template 1) :
https://drive.google.com/open?id=0B0PL_Q...mtDSzJObFU
Link to the custom list (custom 1) :
https://drive.google.com/open?id=0B0PL_Q...VhfRzREdm8
Instruction :
1. Download and overide the Designer_CustomList1.xml in the /16x9 folder of the skin
2. Go to the skin settings Import / Export
3. Choose Import... and browse the first downloaded file (BookMark View.zip) (this will overide template 1)
4. Go to the Designer
5. Browse the section you want to apply the template
6. Browse a free view or one you want to overide
7. Press enter or click the view name
8. Scroll down to "Template 1" and choose apply template to view
Your done ! Just select the view in the corresponding section.
FIXED LIST NO ART VIEW [MOD] (REQUEST)
Original FIXEDLIST variation requested without Art / Thumbs / Icons :
Itemlayout :
        <itemlayout width="636" height="119">
                    <left>0</left>
                    <top>0</top>
                    <height>118</height>
                    <align>center</align>
                    <bordersize>0,0,1,0</bordersize>
                    <texture border="0,0,1,0" colordiffuse="$INFO[Skin.String(Color.B1ItemNF)]">common/white.png</texture>
                </control>
                    <left>24</left>
                    <top>20</top>
                    <width>588</width>
                    <height>50</height>
                    <align>left</align>
                    <aligny>center</aligny>
                    <font>Font27</font>
                    <label>$VAR[B1Title]</label>
                </control>
                    <left>24</left>
                    <top>50</top>
                    <width>588</width>
                    <height>50</height>
                    <align>left</align>
                    <label>$VAR[B1SubTitle]</label>
                </control>
            </control>
                <right>1</right>
                <top>0</top>
                <width>100</width>
                <height>100</height>
                    <right>0</right>
                    <top>0</top>
                    <texture colordiffuse="$VAR[CategoryColor]">common/corner.png</texture>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                    <texture colordiffuse="$INFO[Skin.String(Color.B1Txt1F)]">material/check.png</texture>
                    <visible>!ListItem.HasTimer + !ListItem.IsRecording + !ListItem.IsResumable</visible>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                    <texture colordiffuse="$INFO[Skin.String(Color.B1Txt1F)]">osd/pause.png</texture>
                    <visible>ListItem.IsResumable</visible>
                </control>
                <!-- Recording image -->
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                    <texture colordiffuse="$INFO[Skin.String(Color.B1Txt1F)]">osd/record.png</texture>
                    <visible>ListItem.IsRecording</visible>
                </control>
                <!-- Timer image -->
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                    <texture colordiffuse="$INFO[Skin.String(Color.B1Txt1F)]">material/clock.png</texture>
                    <visible>ListItem.HasTimer + !ListItem.IsRecording</visible>
                </control>
            <visible>[Skin.HasSetting(WatchedFlag) + [Container.Content(movies) + stringcompare(ListItem.Overlay,OverlayWatched.png)] | [Container.Content(episodes) + stringcompare(ListItem.Overlay,OverlayWatched.png)] | [Container.Content(seasons) + stringcompare(ListItem.Overlay,OverlayWatched.png)] | [Container.Content(tvshows) + stringcompare(ListItem.Overlay,OverlayWatched.png)] | ListItem.IsResumable] | ListItem.IsRecording | ListItem.HasTimer</visible>
            </control>
        </itemlayout>
Focusedlayout :
        <focusedlayout width="636" height="118">
                    <left>0</left>
                    <top>0</top>
                </control>
                    <left>0</left>
                    <top>0</top>
                    <texture border="0,0,1,0" colordiffuse="$VAR[CategoryColor]">common/white.png</texture>
                </control>
                    <left>24</left>
                    <top>20</top>
                    <width>588</width>
                    <height>50</height>
                    <align>left</align>
                    <font>Font27</font>
                    <textcolor>$INFO[Skin.String(Color.B1Txt1F)]</textcolor>
                </control>
                    <left>24</left>
                    <top>50</top>
                    <width>588</width>
                    <height>50</height>
                    <align>left</align>
                    <textcolor>$INFO[Skin.String(Color.B1Txt2F)]</textcolor>
                </control>
            </control>
                <right>1</right>
                <top>0</top>
                <width>100</width>
                    <right>0</right>
                    <top>0</top>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
            </control>
        </focusedlayout>
Link to the custom list (custom 2) :
https://drive.google.com/file/d/0B0PL_QS...sp=sharing
Instruction :
1. Download and overide the Designer_CustomList2.xml in the /16x9 folder of the skin
Your done ! Just select the ListType CUSTOM2 in the Designer Bloc1.
AlbumWall View (recommended for 3xH and 1xW)
Download Frame (insert into Skin Folder)
Itemlayout:
<itemlayout width="212" height="213">
                <height>212</height>
                <aspectratio>stretch</aspectratio>
                <texture fallback="osd/audio.png">$VAR[ThumbPortrait]</texture>
            </control>
                <height>370</height>
                <left>0</left>
    <textcolor>75ffffff</textcolor>
                <label>[UPPERCASE]$INFO[Skin.String(Color.B1ItemFMUS)][/UPPERCASE]$INFO[ListItem.Label]</label>
            </control>
            </itemlayout>
Focusedlayout:
<focusedlayout width="212" height="213">
</control>
                    <left>-7</left>
                    <top>-6</top>
                    <width>225</width>
                    <height>225</height>
                    <texture colordiffuse="$VAR[CategoryColor]">common/flag_frame3.png</texture>
            </control>
                    <left>4</left>
                    <top>168</top>
                    <width>203</width>
                    <height>40</height>
                    <texture colordiffuse="ff000000">common/white.png</texture>
</control>
                <left>0</left>
<textcolor>FFFFFFFF</textcolor>
                 </control>
        </focusedlayout>
(2016-01-23, 19:58)Shogun Wrote: [ -> ]AlbumWall View (recommended for 3xH and 1xW)
Good job ! Nod
Like it Cool
LANDSCAPE ART VIEW [FANART MOD] (REQUEST)
Original FANART variation requested showing LANDSCAPE ART instead.
Fanart as fallback.
REQUIRES ARTWORK.DOWNLOADER INSTALLED (check skin settings > enhancement)
Itemlayout :
        <itemlayout width="636" height="356">
                <left>0</left>
                <top>0</top>
                <width>635</width>
                <height>355</height>
            </control>
                <left>197.5</left>
                <top>8</top>
                <width>240</width>
                <height>240</height>
                <texture background="true" colordiffuse="$INFO[Skin.String(Color.B1Txt1NF)]">$VAR[ThumbIcon]</texture>
                <visible>[IsEmpty(ListItem.Property(ChannelName)) + IsEmpty(ListItem.ChannelName)] + [ListItem.IsFolder | IsEmpty(ListItem.Art(thumb)) | !IsEmpty(ListItem.Property(labelID))]</visible>
            </control>
                <left>0</left>
                <top>1</top>
                <width>635</width>
                <aligny>top</aligny>
                <texture background="true" colordiffuse="FFFFFFFF">$INFO[ListItem.Art(landscape)]</texture>
                <visible>!IsEmpty(ListItem.Art(landscape))</visible>
            </control>
                <left>0</left>
                <top>1</top>
                <width>635</width>
                <texture background="true" colordiffuse="FFFFFFFF">$VAR[ThumbLandscape]</texture>
                <visible>IsEmpty(ListItem.Art(landscape))</visible>
            </control>
                <right>0</right>
                <top>0</top>
                <width>100</width>
                    <right>1</right>
                    <top>1</top>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
            </control>
                    <left>0</left>
                    <top>256</top>
                    <width>635</width>
                    <animation effect="fade" start="100" end="80" time="0" condition="true">Conditional</animation>
                </control>
                    <left>0</left>
                    <top>256</top>
                    <width>100</width>
                    <texture background="true" colordiffuse="FFFFFFFF">$INFO[ListItem.Art(thumb)]</texture>
                    <visible>Container.Content(songs) | !IsEmpty(ListItem.Artist)</visible>
                </control>
                    <left>10</left>
                    <top>266</top>
                    <width>80</width>
                    <height>80</height>
                    <texture background="true" colordiffuse="FFFFFFFF" fallback="material/tv.png">$VAR[ThumbTV]</texture>
                    <visible>!IsEmpty(ListItem.Property(ChannelName)) | !IsEmpty(ListItem.ChannelName)</visible>
                </control>
                    <animation effect="slide" start="0,0" end="100,0" time="0" condition="Container.Content(songs) | !IsEmpty(ListItem.Property(ChannelName)) | !IsEmpty(ListItem.ChannelName) | !IsEmpty(ListItem.Artist)">Conditional</animation>
                        <left>12</left>
                        <top>266</top>
                        <width>512</width>
                        <height>50</height>
                        <align>left</align>
                        <font>Font27B</font>
                    </control>
                        <left>12</left>
                        <top>296</top>
                        <width>512</width>
                        <height>50</height>
                        <align>left</align>
                    </control>
                </control>
            </control>
        </itemlayout>
Focusedlayout :
        <focusedlayout width="636" height="356">
                <left>0</left>
                <top>0</top>
                <width>635</width>
            </control>
                <left>197.5</left>
                <top>8</top>
                <width>240</width>
            </control>
                <left>0</left>
                <top>1</top>
                <width>635</width>
            </control>
                <left>0</left>
                <top>1</top>
                <width>635</width>
            </control>
                <right>0</right>
                <top>0</top>
                <width>100</width>
                    <right>1</right>
                    <top>1</top>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
            </control>
                    <left>0</left>
                    <top>256</top>
                    <width>635</width>
                </control>
                    <left>0</left>
                    <top>256</top>
                    <width>100</width>
                </control>
                    <left>10</left>
                    <top>266</top>
                    <width>80</width>
                    <height>80</height>
                </control>
                        <left>12</left>
                        <top>266</top>
                        <width>512</width>
                        <height>50</height>
                        <align>left</align>
                    </control>
                        <left>12</left>
                        <top>296</top>
                        <width>512</width>
                        <height>50</height>
                        <align>left</align>
                    </control>
                </control>
            </control>
                <left>0</left>
                <bottom>0</bottom>
                <width>635</width>
                <height>8</height>
            </control>
        </focusedlayout>
Link to the custom list (custom 3) :
Instruction :
1. Download and overide the Designer_CustomList3.xml in the /16x9 folder of the skin
Your done ! Just select the ListType CUSTOM3 in the Designer Bloc 1.
VIEW POSTER SLIDE :
https://www.dropbox.com/s/bp2xxgwl8odcre...r.rar?dl=0 ( unzip the file and follow the instructions.)
I use the Skin Frames Posters Conq on, if you do not want to use, not to copy the Media folder.
REQUIRES ARTWORK.DOWNLOADER INSTALLED (check skin settings > enhancement) : Download Logo
To create this view, you must import the Template Post slide and assign to the view you want to change.
Then copy MEDIA folder in your file : C:\Users\YourNAME\AppData\Roaming\Kodi.
copied the folder 16X9 and replaced Custom_List 3 file :
In the Builder view go in
bloc 1, select Image: Choose Image :Fond Black background.png
Bloc 2 : select image : Choose Image :Fond Black background.png
Bloc 3 Confusedelect image : Choose Image :Fond Black background.png
Bloc Background : Select image : vignette_slide.png
You can copy images to a folder in the folders of your backups KOVER views, and then assign the PNG images in the block.
]<!-- Custom List 3 -->
         <itemlayout width="275" height="1067">
        <top>225</top>
         <left>15</left>
                    <left>0</left>
                    <top>0</top>
                    <width>255</width>
                    <height>381</height>
                </control>
                    <width>255</width>
                    <texture colordiffuse="FFFFFFFF">$VAR[ThumbPortrait]</texture>
                </control>
             <width>255</width>
                   <texture>Frames_Sup/OverlayPosterNF.png</texture>
                   <aspectratio align="center" aligny="top">stretch</aspectratio>
                   </control>
            </control>
        </itemlayout>
        <focusedlayout width="275" height="1067">
        <animation type="Focus">
     <effect type="fade" start="60" end="100" time="150" tween="sine" easing="out"  />
            <effect type="zoom" tween="Quadratic" start="100" end="130" center="112,350" easing="Out" time="125"/>
        </animation>
        <animation type="UnFocus">
            <effect type="zoom" tween="Quadratic" start="130" end="100" center="112,100" easing="Out" time="125" />
        </animation>
        <top>225</top>
         <left>15</left>
                    <left>0</left>
                    <top>0</top>
                    <width>255</width>
                </control>
                    <left>0</left>
                    <top>-0</top>
                    <width>255</width>
                </control>
              <left>0</left>
                    <top>-0</top>
                    <width>255</width>
                   <texture>Frames_Sup/OverlayPosterFO.png</texture>
                   </control>
        </control>
        </focusedlayout>
if you want use only desiger_Custom-List3.xml
Color Light :
other configuration whith FTV Styles color /
You can not add Block 3 in this configuration, because the Bloc is 3 under the block 1.
View List Opacity : You must use Theme Dark Color for best render
To create this view, you must import the Template List Opacity( .rar) and assign to the view you want to change.
Bloc4 Confusedelect image : Choose Image :Fond Black background.png
Bloc Background : Select image : Bloc Background leftright.png
View List Opacity
https://www.dropbox.com/sh/kyjyzzcvdcst0...zYCBa?dl=0
Your done ! Just select the ListType CUSTOM2 in the Designer Bloc1. This is intended to be used with a 3x3 layout, Verticall scroll
Use only Block 1 in 3X3, requested without Art / Thumbs / Icons
<itemlayout width="1900" height="215">
                        <left>20</left>
                        <top>4</top>
                    <left>15</left>
                    <top>15</top>
                    <width>260</width>
                    <height>170</height>
                    <texture border="0,0,1,0" colordiffuse="AAFFFFFF">common/white.png</texture>
                </control>
                    <left>20</left>
                    <top>20</top>
                    <width>250</width>
                    <height>160</height>
                </control>
                  <right>25</right>
                    <top>35</top>
                    <width>220</width>
                    <texture colordiffuse="FFFFFFFF">$INFO[ListItem.Art(clearlogo)]</texture>
                </control>
                    <left>0</left>
                    <top>0</top>
                    <height>205</height>
                    <texture border="0,0,1,0" colordiffuse="BB000000">common/white.png</texture>
                </control>
                    <left>300</left>
                    <top>15</top>
                    <width>1825</width>
                    <height>50</height>
                    <align>left</align>
                    <font>Font30</font>
                </control>
                    <left>300</left>
                    <top>150</top>
                    <width>500</width>
                    <height>50</height>
                    <align>left</align>
                </control>
                    <left>300</left>
                    <top>150</top>
                    <width>200</width>
                    <height>50</height>
                    <align>left</align>
                </control>
                    <left>500</left>
                    <top>150</top>
                    <width>600</width>
                    <height>50</height>
                    <align>left</align>
                    <label>$VAR[B2SubTitle]</label>
                </control>
                   <top>60</top>
                    <left>300</left>
                   <width>1300</width>
                    <height>90</height>
                </control>
                    </control>
                <right>1</right>
                <top>0</top>
                <width>100</width>
                    <right>0</right>
                    <top>0</top>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
            </control>
                </itemlayout>
                <focusedlayout width="1900" height="215">
                <left>20</left>
                <top>4</top>
                    <left>0</left>
                    <top>0</top>
                </control>
                    <left>15</left>
                    <top>15</top>
                    <width>260</width>
                </control>
                    <left>20</left>
                    <top>20</top>
                    <width>250</width>
                </control>
                  <right>25</right>
                    <top>35</top>
                    <width>220</width>
                </control>
                    <left>300</left>
                    <top>15</top>
                    <width>1825</width>
                    <height>50</height>
                    <align>left</align>
                    <font>Font30</font>
                </control>
                    <left>300</left>
                    <top>150</top>
                    <width>200</width>
                    <height>50</height>
                    <align>left</align>
                </control>
                    <left>500</left>
                    <top>150</top>
                    <width>600</width>
                    <height>50</height>
                    <align>left</align>
                </control>
                    <top>60</top>
                    <left>300</left>
                   <width>1300</width>
                    <height>90</height>
                </control>
                    </control>
                <right>1</right>
                <top>2</top>
                <width>100</width>
                    <right>0</right>
                    <top>0</top>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>6</right>
                    <top>6</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
                    <right>5</right>
                    <top>5</top>
                    <width>25</width>
                    <height>25</height>
                </control>
            </control>
                </focusedlayout>
https://www.dropbox.com/s/sc4h2e6dfrvdluy/Wall.rar?dl=0
Copy CustomList1.xml and, change in your skin folder 19x9,or/ and you can also use template (images available for block)
Bloc Background : Bloc Background 50%.png
Bloc 2 : Fond Dark.png
Only CustomList.xml whithout template and background .
<?xml version="1.0" encoding="UTF-8"?>
<includes>
    <!-- BUILD YOUR OWN LIST TYPE INSIDE KOver
        You will find below a quick guide to give you more details about variables and settings and help you build your own list.
        Before you start, and for you to get the best results, keep in mind that KOver's grid is made of 9 spaces with a 636 (width) x 356 (height) pixels size.
        If you want your list to fit prefectly when resizing, make your <itemlayout>, <focusedlayout> a multiple of this file :
        Ex : Fanart view is set with <itemlayout width="636" height="356">. Ratio 1:1
        Ex2 : Poster view is set with <itemlayout width="212" height="356">. Ratio 1:3 on width and 1:1 on height
        KOver also handles a dynamic sizing giving you the layout the whole size set in Designer (meaning if you set 1column x 1row, size will be automatically 636x356
        and if you set 3column x 3row will be 1908x1068 ratio 3:1). For this, you can use the following code :
        <itemlayout width="$PARAM[width]" height="$PARAM[height]">
        >> VARIABLES :
        ______________
        The following variables are available inside the list and set to provide the best matching imformations :
        >>>Labels :
        $VAR[B1Title] : Usually the ListItem.Title ot ListItem.Label + fallbacks
        $VAR[B1SubTitle] : Additional informations of an item (ex : duration for movies, start time / end time for PVR, etc.)
        >>>Pictures :
        $VAR[ThumbPortrait] : Return a Portrait picture of an item. Usually Poster or thumb (if episodes) + fallback pictures
        $VAR[ThumbLandscape] : Return a Landscape picture of an item. Usually Fanart or thumb (if episodes) + fallback pictures
        >>>Colors (Colors set in the Color tool) :
        $INFO[Skin.String(Color.B1Bg)] : Bloc 1 background
        $INFO[Skin.String(Color.B1ItemNF)] : Bloc 1 unselected item (itemlayout) background
        $INFO[Skin.String(Color.B1Txt1NF)] : Text 1 unselected item (itemlayout) usually used for titles and icons
        $INFO[Skin.String(Color.B1Txt2NF)] : Text 2 unselected item (itemlayout) usually used for subtitles
        $VAR[CategoryColor] : Bloc 1 elected item (focusedlayout) background. Changes with the category
        $INFO[Skin.String(Color.B1IconBg)] : Icon background overlay (focusedlayout). Shows over the Bloc 1 selected item
        $INFO[Skin.String(Color.B1Txt1F)] : Text 1 selected item (focusedlayout) usually used for titles and icons
        $INFO[Skin.String(Color.B1Txt2F)] : Text 2 selected item (focusedlayout) usually used for subtitles
        Of course, you can also use any of the KODI infolabels instead.
    <!-- Custom List 1 -->
    <!-- DO NOT MODIFY FROM HERE -->
        </control>
    <include name="Custom1">
    <!-- TO HERE -->
<animation type="WindowOpen">
                <effect type="fade" start="0" end="100" time="500"/>
                <effect type="zoom" start="200" end="100" center="auto" time="500"/>
            </animation>
            <animation type="WindowClose">
                <effect type="fade" start="100" end="0" time="500"/>
                <effect type="zoom" start="100" end="200" center="auto" time="500"/>
            </animation>
        <itemlayout width="125" height="178">
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>70</width>
                    <height>110</height>
                    <texture>white.png</texture>
                    <colordiffuse>FFFFFFFF</colordiffuse>
                </control>
                    <left>20</left>
                    <top>30</top>
                    <width>120</width>
                    <height>165</height>
                    <texture>$VAR[ThumbPortrait]</texture>
                     <animation condition="true" effect="Fade" start="30" end="30" time="0">Conditional</animation>
                </control>
        </itemlayout>
        <focusedlayout width="125" height="178">
                    <left>20</left>
                    <top>30</top>
                   <width>120</width>
                     <bordertexture>black.png</bordertexture>
                    <bordersize>2</bordersize>
                    <animation effect="zoom" start="100" end="140" center="auto">Focus</animation>
                    <animation effect="slide" start="0,0" end="11,0" time="0" condition="Container.Column(0)">Conditional</animation>
                    <animation effect="slide" start="0,0" end="-11,0" time="0" condition="Container.Column(15)">Conditional</animation>
                    <animation effect="slide" start="0,0" end="0,17" time="0" condition="Container.Row(0)">Conditional</animation>
                    <animation effect="slide" start="0,0" end="0,-17" time="0" condition="Container.Row(5)">Conditional</animation>
                    <visible>stringcompare(ListItem.Label,..)</visible>
                </control>
                    <posx>0</posx>
                    <posy>0</posy>
                <width>120</width>
                    <texture  background="true"diffuse="white.png">$VAR[ThumbPortrait]</texture>
                    <visible>!stringcompare(ListItem.Label,..)</visible>
                </control>
        </focusedlayout>
    </include>
</includes>
    <!-- TO HERE -->
https://www.dropbox.com/s/djcz5pkdjg8vvh...l.rar?dl=0
Copy and paste CustomList1 in your folder 16X9, and select Bloc1= 3X3 , Bloc Background 3x3 Visible => image => Selected Picture Fanart-Poster Overlays.png
    <!-- TO HERE -->
        </itemlayout>
        <focusedlayout width="$PARAM[width]" height="$PARAM[height]">
            <left>0</left>
                    <top>0</top>
                    <bottom>150</bottom>
                    <left>49</left>
                    <width>1200</width>
                    <height>80</height>
                    <align>left</align>
                    <font>Font60R</font>
                </control>
                    <top>925</top>
                    <left>49</left>
                    <width>1200</width>
                    <height>80</height>
                    <font>Font27</font>
                    <textcolor>EEFFFFFF</textcolor>
                </control>
                    <left>49</left>
                    <top>1020</top>
                    <width>588</width>
                    <height>50</height>
                    <align>left</align>
                </control>
            </control>
            <left>1600</left>
                    <top>700</top>
                    <left>-5</left>
                    <top>-5</top>
                    <width>261</width>
                    <height>361</height>
                    <aspectratio>Stretch</aspectratio>
                    <texture colordiffuse="FFFFFFFF">common/white.png</texture>
                    <visible>!IsEmpty(ListItem.Thumb)</visible>
                </control>
                    <width>250</width>
                    <height>350</height>
                </control>
            </control>
        </focusedlayout>
    </include>
</includes>
    <!-- TO HERE -->
VIew WIDGET ( Only HORIZONTAL )
Customlist2.xml for customization WIDGET. Attention building only for Horizontal menu. I did not check to Vertical menu. And the choice of this WIDGET views are personal to me, so if this does not suit you, you can change either Builder, is the CustomList2.xml file.
We must hide all additional Art in the Builder (unless you want to see, I can no way to prevent you.)
Imperative 1 = BLOCK 3X3
watch gallery
https://www.dropbox.com/sh/6wpymeii3yji6...Bj4La?dl=0
<includes>
        >> VARIABLES :
        ______________
        >>>Labels :
        >>>Pictures :
    <!-- Custom List 2 -->
    <include name="Custom2">
    <!-- TO HERE -->
        <animation type="Conditional" condition="!Control.HasFocus(9000)" reversible="false">
                <effect type="fade"  start="100" end="0" time="0" easing="In" tween="Cubic"/>
            </animation>
         <top>40</top>
                    <left>49</left>
                    <width>55</width>
            <height>55</height>
                    <texture colordiffuse="FFFFFFFF">material/tile.png</texture>
                </control>
                    <top>-10</top>
                    <left>125</left>
                    <width>600</width>
                    <height>80</height>
                    <align>left</align>
                    <font>Font27</font>
                </control>
         </control>
        </itemlayout>
        <focusedlayout width="1850" height="$PARAM[height]">
          <animation type="Conditional" condition="Control.HasFocus(9000)" reversible="false">
                <effect type="Slide"  center="auto" start="0,0" end="0,0" easing="In" tween="Cubic"/>
            </animation>
                <effect type="Slide" time="450" center="auto" start="0,0" end="0,0" easing="In" tween="Cubic"/>
            </animation>
        <top>750</top>
         <left>62</left>
                    <left>-50</left>
                    <top>-70</top>
                    <width>1950</width>
            <height>235</height>
                    <texture colordiffuse="$INFO[Skin.String(Color.B1IconBg)]">common/white.png</texture>
                </control>
                    <left>-5</left>
                    <top>-65</top>
                    <width>160</width>
            <height>222</height>
                </control>
                    <left>0</left>
                    <top>-60</top>
                    <width>150</width>
            <height>210</height>
                    <texture colordiffuse="FFFFFFFF">$INFO[ListItem.Icon]</texture>
                </control>
                <top>-88</top>
                    <left>200</left>
                    <width>1000</width>
                    <height>80</height>
                    <align>left</align>
                    <font>Font36</font>
                </control>
                    <left>200</left>
                    <width>1250</width>
                    <height>145</height>
                    <font>Font27</font>
                </control>
                   <top>-25</top>
                    <left>200</left>
                    <width>328</width>
                    <height>24</height>
                    <align>left</align>
                </control>
        </control>
         </focusedlayout>
    </include>
</includes>
    <!-- TO HERE -->
BIG POSTER 2 : BLOC 1 = 3X2 .
WallPapen =Select Image Fond Dark.png , Bloc Background = Select Fond Dark.png
https://www.dropbox.com/s/ofida0oam6tvka...2.rar?dl=0
    <!-- TO HERE -->
        <itemlayout condition="IsEmpty(Container.FolderPath)" width="815" height="1080">
                      <animation condition="true" effect="Fade" start="25" end="25" time="0">Conditional</animation>
                    <width>800</width>
                    <height>1065</height>
                </control>
        </itemlayout>
        <focusedlayout condition="IsEmpty(Container.FolderPath)" width="1920" height="1080">
                    <width>800</width>
                </control>
        </focusedlayout>
(2016-02-16, 05:54)Reynald Wrote: [ -> ]BIG POSTER 2 : BLOC 1 = 3X2 .
https://www.dropbox.com/home/Kover_view/...oster2.rar
    <!-- TO HERE -->
                    <width>800</width>
                </control>
        </itemlayout>
                    <width>800</width>
                </control>
        </focusedlayout>
Hi Reynald, can't download the rar file from dropbox as I need to register, no option to skip and just download the file, like the widget rar.
Quote:Hi Reynald, can't download the rar file from dropbox as I need to register, no option to skip and just download the file, like the widget rar.
Sorry , all is Ok now
