Full Version: Quartz for Apple TV 4?
My favorite skin is ready to install for ATV4?or not?
Hm.. Yes and no Smile
I don't have KODI skin but I've made Quartz plexconnect theme https://github.com/pecinko/PlexConnectApp
I'm not even sure KODI community would be interested in such "simplified" skin as is Quartz theme above?!?
pecinko
Will Quartz plexconnect work on kodi or is it only for plex, i really like it Smile
Would like to test it on my kodi pc , but it would be soo nice to have on mrmc Smile
I beg of you!!!
Please update Quartz for Jarvis.
I don't want or need any new bells and whistles but it is honestly the only
skin I can stand. It's clean, simple and not all cluttered up needlessly.
If you take donations I'd be more than will to contribute to the update if you'd be up for it.
Your genius and skill is still needed!!
Please keep Quartz alive!
Definitely looking forward to this..
HI Guys
After so long, i'll finally release my modded quartz skin (thanks pecinko) with the moddifications to make it run on Jarvis
This skin includes my little apple esk tweaks so.....
https://www.dropbox.com/s/8g2rh7rai5fmwq...d.zip?dl=0
Be sure to unzip this folder and place it in your addons folder with the rest of your plugins. Once its copied, close and restart Kodi and it should appear as an available skin.
Once this loads up you can modify the titles of the end 3 options from Pictures to Computers, Addons to Internet and XBMC to System.
You will also need to install Skinwidgets plug in if you don't already has this to enable the top row to function.
This modded skin will not have any dependancies and will not install as per normal, you have to copy to the addons folder. So whet you will have is a folder named skin.quartz.modded and within that you will have all the files and folders that make up the skin.
