Just curious if anyone has come across this issue or feature. For some reason the text label displayed. Only the menu item in focus has text all the rest are blank.
Any ideas? I really do not recall changing any related settings that's why is odd to me.
As a test changed skin back to confluence and the reappeared. Switchback to Black Glass Nova and they are gone again. How would I trouble shoot this? Or should I wipe and reinstall everything
Black Glass Nova does not display labels, but simply uses thumbnails instead. Only the central item shiows its label. It's by design
Tgx
(2016-01-18, 21:09)Tgxcorporation Wrote: [ -> ]Black Glass Nova does not display labels, but simply uses thumbnails instead. Only the central item shiows its label. It's by design
Tgx
I'm stupid. Thanks
Tgx
Could this be switched on as for personalization or would that be considered not appropriate?
There's no option for this. Sorry
Tgx
This looks better actually now that I used it more. Thanks for your replies!
